Bar Ends
3 replies to this topic
  • BigVthumper
Posted February 25, 2009 - 04:07 PM
Who makes the most rugged set? I need a set bad
  • RedBull420
Posted February 25, 2009 - 04:23 PM
Bar ends?? You speaking of bark busters / handguards??
I use Cycra Probends, very well make and very tough!
http://store.cycrara...m/cypralha.html
  • Sierra_rider
Posted February 26, 2009 - 01:11 AM
If you do mean handguards, I use the cycra probends as well. I like them a lot.
  • Navaho6
Posted February 26, 2009 - 07:45 PM
If it's bar end weights you want, no one makes them for 7/8" aluminum bars except Faast Co. but they are bar inserts and don't work as good as exterior bar ends. I took the bar end weights off my DR650 and drilled the holes larger. Then put a longer bolt through. For handguards, I use Enduro Engineering. The bar end weights greatly reduce handlebar vibrations but add length. I cut my bars down so that the weights put me back to stock length.
