Mystery of the disappearing O-ring
5 replies to this topic
  • wr400X
Posted February 25, 2009 - 06:42 AM
I am missing the o-ring that goes on the end of the carb side drain screw on my 2000 wr400. Conveniently, the screw and o-ring are conspicuously absent from the parts diagram. See red circle in pic above. That's where the screw with attatched o-ring are supposed to go. I have been to the local bike shop three times now.
I need this o-ring!!!
  • William1
Posted February 25, 2009 - 08:14 AM
No oring used. The screw has a slightly conal tip that closes off the passage way from the bowl to the drain line. I have only seen the screw come with the bowl, though some carb parts places may carry them. It is not considered a normal service item.
  • vfr661
Posted February 25, 2009 - 03:47 PM
I concur with William. There's no o-ring for that screw. The copper tip should seal and prevent gas leaks. If you are leaking gas it could be your float valve. I took my wr400 carb apart and had the same concern but after many hours of inspecting the carb bowl I realized there's no o-ring seal. My carb was leaking and the float vavle was the culprit.
  • wr400X
Posted February 25, 2009 - 06:22 PM
Despite making a fool of myself in my assumption, your replies have helped me realize that must be the problem. Some other o-ring in my recent memory must have got me off track. I will be ordering the needle set asap.
The diagram sure doesn't have the screw in it, so that kind of threw me through a loop as well.
I appreciate your help and hopefully soon I will be tearing it up on my favorite blue machine once again.
thanks
  • Birdy426
Posted February 25, 2009 - 10:41 PM
Try Sudco for the carb parts. Yamaha wants to sell the whole needle/seat assembly. Sudco will sell just the needle. With the rubber tip on the needle, the seat almost never goes bad. Make sure you order the O-Ring that goes around the needle seat as well...as soon as you take the seat out of the carb, that O-Ring will start to leak, and then even if your float is set right and the needle is good, you will still leak past the O-Ring and overflow the float bowl.
  • William1
Posted February 26, 2009 - 03:20 AM
I made additional comments in your other thread (http://www.thumperta...ad.php?t=749922) on this.
