06 yz450 forks on a 02 yz426, am I ok?
5 replies to this topic
  • 426tahoe
Posted February 24, 2009 - 07:54 PM
I was hoping someone knew if I had all I needed to make these forks work.
I have a DH1 triple clamp for an 06 yz, Im getting 06 yz450 forks with the axle and brake bracket. On the 426 is an Imig tripple clamp that I was hoping to pres the steering stem out of and into the DH1, mount up the forks etc., throw in 02 426 wheel/brake caliper and go ride. Is it going to be this easy or am I missing something? Thanks:ride:
Posted February 24, 2009 - 08:49 PM
Not 100% certain, but it may be that simple. In fact, check the length of the steering stem. You may find you don't need the press work.
  • biggazzafaetherigs
Posted February 25, 2009 - 01:39 AM
your 06 wheel and brake should fit the 02 fork, i've inter changed wheels from 01 426, 04 450 and 06 450 with no problems
Posted February 25, 2009 - 07:06 AM
It will if you use '06 spacers.
  • moto2000
Posted February 25, 2009 - 09:23 AM
'07 yz450 forks and clamps on a '01 426....
  • JJRace
Posted February 25, 2009 - 08:41 PM
just swap the stem. all bolts up really easily. You will also need the newer number plate since the mounting bolt is vertical on the newer 03 clamps
But put a set of 05 forks on an 03 yz450f. Great swap! all worked out great.
  • Hot  36 replies
  • 0 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
