Rebuilding 07 yz Clutch OEM. Parts Needed?
5 replies to this topic
  • clutchless
Posted February 24, 2009 - 01:39 PM
Hey Guys,
my clutch is smoked and rather then buying a kit i want replace it with OEM parts from the TT store.
Aside from the 7 Clutch Plates and 8 Friction plates what else is needed?
Springs are in good shape, so i shouldn't need to replace those.
Should i replace any other parts while i am in there?
http://shop.thumpert...007&model=12915
Thanks.
  • usmcpaul
Posted February 24, 2009 - 01:57 PM
From what I have been reading (because I am about to install my Rekluse), I think you need to look at the primary driven gear (#4 on the drawing) to make sure the 'tabs' are not notched out. If they are then you will need a new basket.
  • clutchless
Posted February 24, 2009 - 02:12 PM
Basket is in good shape as well. Thanks for the tip!
Posted February 24, 2009 - 02:31 PM
The springs are so cheap there's no reason not to replace them.
  • clutchless
Posted February 24, 2009 - 03:20 PM
good point. 24.00 extra. should i get new SCREW,WITH WASHER 90159-06010-00 while i am at it?
Posted February 24, 2009 - 03:48 PM
Not unless yours are damaged in some way.
