chain and sprocket replacement
4 replies to this topic
  • ryangavin
Posted February 23, 2009 - 03:39 PM
My sprokets are worn out. I run a o-ring chain and was wondering if I should replace the chain at the same time as the sprockets. I read something once that indicated that if you run an o ring chain that you don't need to replace the chain every time you change sprokets. is this true ?
  • awesomeyz
Posted February 23, 2009 - 03:42 PM
yes replace both. If the sprockets are worn out, the chain is worn out too.
  • FoxRacer_357
Posted February 23, 2009 - 03:53 PM
Yea I would say do both too, that way they both wear at the same rate.
  • b--man426
Posted February 23, 2009 - 04:01 PM
I replace all as a set as standard practice-- you can measure the chain to determine if it's worn to far. 10 links no longer than 6" if I remember right - check the manual it should be in there.
Posted February 23, 2009 - 04:19 PM
You are close. measuring between the inner surface of one roller and the inner facing surface of the tenth one away from that (11 total rollers), a new chain will measure 5.85". A chain worn to measure 6" anywhere along its length is "stretched" 2.5% and should be replaced. Personally, I replace them at 5.95" (+1.7%). A caliper makes an easy measurement by this method.
If the chain is any longer than +2% it will wear your new sprockets in a hurry.
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • Hot  28 replies
