how hot is to hot?
14 replies to this topic
  • kingquad450
Posted February 23, 2009 - 01:56 PM
With all this talk about over heating how hot is to hot for the bikes? When should I start getting worried, I just installed a Trail Tech Vapor on my wr426 so I can tell the temp but not sure on what is to hot? Thanks In advance
  • kingquad450
Posted March 22, 2009 - 04:18 PM
anybody?
  • roushxteam199
Posted March 22, 2009 - 05:29 PM
on my 450 i dont like 200deg
  • Krannie McKranface
Posted March 22, 2009 - 06:02 PM
If you bike is box-stock, it comes excessively lean from the factory. This makes the bike run hot. Re-jetting cures all but most difficult overheating issues.
  • kingquad450
Posted March 23, 2009 - 02:38 AM
I got it used, but it has been modded before I got it. It running plenty rich right now. Thanks for the input guys.:thumbsup:
  • flyer05
Posted March 23, 2009 - 11:36 AM
I got my vapor set to 210
  • geoffro
Posted March 25, 2009 - 10:36 PM
If you been riding four strokes a while you will get used to the feel of more heat from the engine through your mx pants.(not like 2 stroke).
That said if you do alot of technical sections one day and its very hot out you will even feel it get hotter through your pants. Sometimes even experience a bit of "burning smell".To me that was my warning,switch off to cool down or get out of the riverbed/rocky section for more airflow!!:thumbsup:
  • graazzy
Posted March 26, 2009 - 01:05 AM
If it's smokin' , it's too hot!
  • rufusz
Posted March 26, 2009 - 07:00 AM
When the water shoots out, than it's time to speed up or to kill it
  • face_plant
Posted March 26, 2009 - 10:34 AM
i have had her up to 250, last overheat my sensor was not working
115-130 was average with engine ice and on the street
  • coyo
Posted June 28, 2009 - 10:11 PM
Stupid question, I'm sure, but where does it shoot from when it's too hot?
  • harvmushman
Posted June 29, 2009 - 06:05 AM
Coolant first goes into the coolant recovery bottle. Good idea to locate this item. If it overheats so much that the bottle is filled, a hose runs from here down to the ground behind the carb with the carb vent lines.
  • MotoGoalie
Posted June 29, 2009 - 02:53 PM
If you search Hardrock RMEC race, colorado 2009. a trials like rock section had all kinds of slipping of clutch and cussing of traction/gravity etc.
i had my 06 WR boiling gas and the tank swelled up as i had a one way vent on the tank.
i took that off and put on a regular uncorked vent hose.
the tank swelled up so much it popped off its grommets. its an IMS oversize tank btw
  • coyo
Posted June 30, 2009 - 02:35 AM
And this is the question then; the previous owner has done a bunch of weird stuff to this thing, the overflow bottle on mine has the line leading in, but no other leading out...
  • DS-WR450F
Posted July 01, 2009 - 09:03 PM
I set the early warning light at 200, and the red warning at 225. Mine usually pukes some coolant around 230. I like having the Vapor, because when the yellow light comes on at 200, I can usually get some airflow, and get it cooled down before it overheats.
