hard shiffting into first.
7 replies to this topic
  • gone_pro
Posted August 02, 2002 - 05:58 PM
Please give your input into why my bike is difficult to **** from 2nd into first. I always need to let the cluth out a little to put presure on the trans. to get it to slid into first gear. Seams to get worse when it is warm. I have tried to adjust the clutch way out. This only helps a "little". Give me your thoughts!
  • Rich_in_Orlando
Posted August 02, 2002 - 06:08 PM
The pinch bolt on the gear shift lever gets loose rather quickly on my bike. I notice it because shifting gets a little sloppy. Tighten it back up and the problem goes away.
  • sabin
Posted August 02, 2002 - 06:18 PM
I do not know on this bikes, but my XT used to have this problem when I overtighten the chain.
I also got the same problem with my XR after a long wheelie, the oil from the frame gets in the engine, so maybe check your engine oil level also...
  • tk421
Posted August 02, 2002 - 06:39 PM
Also you may want to change over (if not already) to synthetic oil. Helps for smoother shifts.
  • ratbiker
Posted August 02, 2002 - 06:48 PM
i had this problem and a buddy said i was not pulling clutch in all the way!Turns out i was pulling it in like i did while i was riding(like maybe half way).Had to concentrate for awhile on pulling all the way in,problem fixed TRY IT MIGHT BE YOU NOT BIKE! :)
[ August 02, 2002: Message edited by: ratbiker ]
  • tk421
Posted August 02, 2002 - 07:13 PM
Say Rich, when you jetted your bike what were the results of EMM clip #4?
  • Rich_in_Orlando
Posted August 04, 2002 - 08:50 AM
At clip #4, the bike runs rougher and blubbers a little on mid-throttle acceleration. But that's just because of the current weather conditions in Florida. The humidity is near 100% all the time lately and it's been consistently in the 90s. When it was cooler, a larger MJ (158-160) and EMM clip #4 made it run just fine. As you can see from my signature, I've got it on clip #3 and a 155 MJ right now.
[ August 04, 2002: Message edited by: Rich in Orlando ]
  • tk421
Posted August 04, 2002 - 11:47 AM
Yes, Taffy’s numbers work well.
In my area the humidity and temperatures are always fluctuating. I have found mine to run a little rough on 90 plus degree-days with humidity around 75 percent. I noticed it runs it’s hardest when temps are in the 70’s and humidity is below 60 percent.
I would think with the larger displacement, open exhaust, cf airbox, and YZ timing, my numbers should be at or below where you are Rich.
