yz426 hotcams ex cam only?
10 replies to this topic
  • aj_yz426
Posted February 21, 2009 - 08:10 AM
Just bought a very clean '01 yz426, still has original tires, very little boot rub marks, etc. and 100% stock. Only thing the previous owner did was regularly change oil/filter and clean air filter. Never adjusted or checked valves.
I'm in the process of sorting through servicing suspension/seals, brakes, carb (did BK and jamesnow mod), oil, fluids, engine etc. since its been stored for a while.
It starts and runs very well (despite cold weather in Michigan now), but can hear noises from valve train and chain, maybe that's normal? Topend looks OK from what I can see, intake valves are just at the lower limit of spec and ex valves are 0.18mm (spec per manual is 0.20-0.25mm). Since I'm going to be changing shims and will have cams off, I plan to do the "DCM" mod and new cam chain I read about here:thumbsup:
Question is: I can't find a used 03-05 stock yz450 ex cam. I've skimmed the 36 pages on the DCM thread and can't find a definite answer from some one who has done just the hotcams ex cam with the stock in cam. I think it will be OK, anyone know for sure?
Thanks.
  • 642MX
Posted February 21, 2009 - 09:26 AM
Yes, you can use a Hot Cam on the exhaust side and a stock cam on the intake.
You might want to replace the timing chain while your at it. They are the weak link in the YZF and should be replaced yearly.
  • aj_yz426
Posted February 21, 2009 - 11:50 AM
Thanks! New cam chain is going in too.
  • shrekka
Posted February 23, 2009 - 08:31 PM
trust me, l had a 2003 YZ450 cam in my 2002 426, then put a hotcams exhaust cam in it, and honestly there is no difference in power...dont bother with hotcams stuff l; reckon for the 426 as its a waste of $$$
  • rufusz
Posted February 23, 2009 - 11:13 PM
Main benefit for a 426 is the auto-decomp ! Worth every penny!
  • 02WR426Cali
Posted February 23, 2009 - 11:21 PM
Yeah you won't see any more power from just the exhaust, you have to put the hotcam intake as well for that. But it might change the power spread a little. I just installed a hotcam ex cam in my bike yesterday. I started it and warmed it up and just cruised up and down the street, so I haven't really tested how it runs but having no starting drill is nice. It feels so weird to not have a drill anymore, but it's nice!
Posted February 24, 2009 - 07:46 AM
Either the OEM 450 cam or the Hot Cams exhaust will have the effect of widening and flattening the power curve, adding to the low end, and smoothing out the peakiness somewhat. Two years ago, when the OEM cam could be had for $100 new, it was a far better deal, but with prices as they currently are, and with the refinements to the Hot Cams product, the aftermarket part may be a better choice, all around. If nothing else, it drops right in and the timing can be set without any special procedures, and the sprocket is a better fit to the chain.
  • aj_yz426
Posted February 24, 2009 - 09:21 AM
The stock exhaust cam new is about $200 here. I picked up a new hotcams on ebay for about $129 (plus I had an 8% off coupon). So the cost and the fact that I don't have to count links and worry about timing marks being off on the stock cam makes it a no brainer.
Thanks for the help.
To be safe I should torque the cam bolts to about 75 in pounds right (not the 86 or whatever in the manual)?
Posted February 24, 2009 - 09:25 AM
That's my opinion, yes. And, always seat the bearing cap by hand rather than drawing it down with the bolts, and run the torque up in 3-4 increments.
  • whyzee426F
Posted July 08, 2009 - 08:02 PM
Gray,
I have the hotcams exhaust and can't seem to find info as to whether or not there is an advantage to adding the hotcams intake cam into the mix. Any idea?
Thanks
Posted July 08, 2009 - 08:14 PM
Supposed to be a minor boost in that. Don't know from personal experience.
  • 0 replies
  • Hot  28 replies
  • On January 15, 2017
  • Hot  47 replies
  • 9 replies
