98 WR400 Headlight
9 replies to this topic
  • gator4life108
Posted February 20, 2009 - 08:35 PM
I recently acquired a 98 WR400, there is currently no headlight on it, just a number plate. It does have a engine kill switch.
My question is, didnt all WR400's come with a headlight?
Can one be hooked up with ease. Anyone have any experience with this.
Thanks,
  • acarter92
Posted February 21, 2009 - 04:26 AM
They all came with a headlight. I'm sure it was there at some point just that someone took it off. Meaning that the wiring is probably there. If the wiring is there just get a used one off of ebay.
Austin
  • gator4life108
Posted February 21, 2009 - 08:00 AM
I have checked up and down the entire frame and I can't find anything, thats what seemed so odd about it.
Thanks,
  • gator4life108
Posted April 17, 2009 - 06:36 AM
So, still trying to figure out the wiring for this headlight.........there are no loose or cut wires that would make me think that there was ever a headlight on the bike.
Could someone tell me where the headlight would normally plug into? or wire into
Thanks,
Mike
  • Birdy426
Posted April 17, 2009 - 09:09 PM
Yellow and black wires under the tank. 2 prong white plastic connector.
  • speedcomm
Posted April 18, 2009 - 01:47 AM
Mine has a 3 wire plug. Yellow black and blue. The plug is on the main frame behind the petcock. This plug has hot power ( yellow wire ) from the stator/regulator, the headlight switch plugs into this plug, blue wire runs to the tail light, black is ground.
  • gator4life108
Posted April 18, 2009 - 04:44 PM
Absolutely nothing.....Im starting to think that my bike is really a YZ, the guy that sold it to me said it was a WR.
It has all the characteristics of a YZ, but I have no way to tell.
  • Birdy426
Posted April 19, 2009 - 10:01 PM
The muffler in your other post looks to be stock WR. 18 or 19 inch rear wheel? 18 is WR, 19 is YZ (though they can be swapped)...Does it have a voltage regulator on the L/H side of the steering stem (about a 2 x 3 inch box with fins on it)? If you pull the magneto cover (L/H side cover), is the flywheel a big ole thing that covers the coils (WR), or an internal rotor one that rotates inside the coils (YZ)?
  • gator4life108
Posted April 20, 2009 - 05:47 AM
Just checked the bike. It has a 19 inch wheel and no voltage regulator, no signs of one ever being there either.
Gotta go to work so didn't have time to pull the magneto cover.
  • gator4life108
Posted April 20, 2009 - 07:02 PM
Yep its a YZ, that makes things a lot easier.
