wr450 2007 coolant leak
16 replies to this topic
  • WRtaz
Posted February 20, 2009 - 08:45 AM
Over the past few weeks when I started the bike I noticed some coolant dripping from under the bike. I just traced it down to under the water pump. There seems to be a small hole under the pump where it's coming from. This is a manufactured hole not from damage. I checked all the bolts so they're all good.
It seems to happen if it has a hard time starting, I think it stops after that. Is this normal or something to be concern about? The radiator is full to the top but the reserve was a bit low. I just added a bit.
  • honeycutt
Posted February 20, 2009 - 08:56 AM
That's the weep hole and usually means that the waterpump seals are bad. Same thing on my 07 WR450. Pretty easy fix and there are quite a few threads on here describing the fix. The seals are on the impellar shaft. Good luck.
  • WRtaz
Posted February 20, 2009 - 10:49 AM
Thanks - I'll get some seals ordered up.
  • maincrash
Posted February 20, 2009 - 11:18 AM
Hey hey you should also order the impeller shaft to its most likely worn and will just where out the new seals.
  • acarter92
Posted February 20, 2009 - 12:42 PM
Copied and pasted from the FAQ sticky!
Q: There's a little hole that dribbles coolant out when the bike is cold, but then it stops. What's that all about?
A: That's the weep hole designed to let you know when it's time to change out the water pump shaft and seals. It happens to all WR's eventually and is a fairly simple repair. It is designed this way so you are alerted to the problem prior to it becoming a major issue. The p/n's for the repair parts are as follows:SHAFT, IMPELLER - 5GR-12458-00-00
OIL SEAL - 93109-11073-00
OIL SEAL,SD-TYPE - 93102-12321-00
BEARING - 93306-00105-00
Austin
  • face_plant
Posted February 20, 2009 - 01:33 PM
where is that horse i wanna kick em in the nutz
the starting problem may be a dirty carb or valve adjustment
  • WRtaz
Posted February 20, 2009 - 07:38 PM
The starting is only a bit of a problem for a few reasons actually. Sitting in garage at 20 degrees during night, just put a Dr D's exhaust on and messing with the jetting (to rich now). I'll work on that after the water pump is fixed.
It kind of sucks that it already needs this stuff done to it. It's only a year old with about 1200 miles on it, just about all dirt. I would have figured a few more years before something like this. I'll get the items ordered tonight, seems pretty easy looking at the shop book as stated.
The bike is awesome either way!
  • zukrider
Posted February 20, 2009 - 09:18 PM
I just replaced the seals in mine tonight. It's pretty easy took about 2 hours being overly cautious.
  • dougEfresh223
Posted February 20, 2009 - 11:18 PM
I think there is an inner and outer seal.....I have had the outer one go bad and leak from that hole. I guess the inner is a little more of a bitch to change than the outer.
  • nitronaf
Posted February 22, 2009 - 07:51 AM
is it really necessary to get a new bearing?
  • zukrider
Posted February 22, 2009 - 08:17 AM
I didn't but I also reused the shaft. The bearing and the shaft seemed fine. I will know soon enough after a few rides if it will be ok. A Lot of guys have just changed the outer seal and have been just fine. If the bearing is still tight and spins smooth you should be fine.
  • WRtaz
Posted February 22, 2009 - 08:46 AM
I ordered these parts from thumpertalk which was about $50. I'll see what the shaft and bearing looks like when I tear into it but more likely than not I'll just replace them. Rather do this once since I'll need to drain the oil and coolant.
Any reason to replace the impeller while I'm in there? I hear you can get an aftermarket one that moves more volume. I haven't had any overheating issues and just engine ice.
MAHA_5GR-12458-00-00 Yamaha SHAFT, IMPELLER
YAMAHA_93102-12321-00 Yamaha OIL SEAL,SD-TYPE
YAMAHA_93109-11073-00 Yamaha OIL SEAL
YAMAHA_93306-00105-00 Yamaha BEARING
  • ch_250
Posted February 27, 2009 - 01:54 PM
i ordered the whole kit and couldn't tell the difference between the new and old bearing. i changed mine in summer and it fixed it, but when it's cold it leaks a little when i start it, it stops after like two drips. Other guys say the same, it's normal as long as it doesn't get in with your oil. just make sure your oil isn't milky at all.
  • pako.major
Posted August 19, 2014 - 11:07 AM
Not to re-hash and old topic, but here i go. This was the reported fix for the 2007 WR450. My bike is a 2006 WR450, but it's having the same problem. Do the parts listed above translate to the 2006 as well?
Also, is there a tutorial or how-to anywhere online on how to do this?
  • still2smokin
Posted August 19, 2014 - 03:58 PM
They might be the same parts but to be sure you should check the OEM parts schematic at the thumpertalk store or RMATV.
You should buy the seals and impeller shaft .
Or you can buy an aftermarket water pump and it will have all the parts you need plus it moves more water.
  • pako.major
Posted August 20, 2014 - 09:29 AM
Is there an actual noticeable differnce when getting an aftermarket water pump? I was riding this past weekend at high altitude (11-13k feet), and the bike was getting pretty damn hot. Will this make anactual difference in the bike's running and reliability?
  • still2smokin
Posted August 20, 2014 - 08:53 PM
It runs cooler for sure, but only when you have good airflow .
Don't know how much it helps when you are just creeping along , but that's where a fan comes in handy.
