06 WR450 Mods
10 replies to this topic
  • Tonyf6188
Posted February 19, 2009 - 05:38 AM
I am new to this forum and the WR! I have a few questions. If I do the mods to the new bike (Air box cut out, AIS removal, Baffle removal, Throttle stop screw, Grey wire disconnect) will I have to re-jet the bike for it to run properly and be dependable?
  • Krannie McKranface
Posted February 19, 2009 - 06:31 AM
Yes. If you introduce more air (airbox mod, pipe mod) you will make the engine run leaner. It already comes too lean from the factory. Buy a jetting kit (JD) and learn about the Accelerator pump mods too.
  • Zadok
Posted February 19, 2009 - 06:45 AM
No offense to anyone, you have to learn somewhere.
But Im still really amazed at how many times this same
question comes up. Guess it just seems that riders would
understand that more air in, and more air out would
require more fuel to maintain the proper air/fuel ratio.
I think its time we all get Closed Loop EFI systems that
will self adjust to the changes.....:lol:
  • Tonyf6188
Posted February 19, 2009 - 09:19 AM
I guess I should have been a little more clear in my question. What I meant to ask is am I going to have to re-jet the carb other than the new jets that come with the AIS removal kit. From what I am told it comes with everything you need including all the new jets needed. Maybe that is a little more direct question.
  • KennyMc
Posted February 19, 2009 - 09:41 AM
Check out the post by Indy WR450 for jetting specs. I believe the AIS removal jet that comes with the kit is a 170. From all I have read, this is too rich. I used the AIS removal kit but also got the JDJetting kit to handle the jetting. I went with the 168 main and 48 pilot and the other jets that came with the JD kit.
http://www.thumperta...ad.php?t=411240
  • buspilot
Posted February 19, 2009 - 11:23 PM
I just did this modifications 2 weeks ago and turned out with a 170 main and 48 pilot. Here are the results:
  • hillclimbguy
Posted February 20, 2009 - 07:56 AM
I just pulled out that airbox venturi. Did notice a difference.
  • dougEfresh223
Posted February 20, 2009 - 11:37 PM
whats that 37hp?
  • NortonMoto
Posted February 21, 2009 - 09:41 AM
Do you have before and after dyno?
  • Tonyf6188
Posted February 25, 2009 - 04:19 AM
Now that I have done all of the mods I am having two issues. (1) I still have the bog with a whack of the throttle and (2) after riding for several minutes and cranking on the throttle alot, the bike idles really high. If I put in a lower gear, let off the clutch, and then re-engage the clutch, the high idle goes away but comes back later if I allow the bike to stay idling. It does not do this until I have ridden a little while. From a cold start it idles fine and does not do that even when it starts to get really hot. I now have the JD kit and will install along with a 40 Leak jet. What else can I do to fix these two problems?
  • jtn 06 wr450
Posted February 25, 2009 - 08:20 AM
tony, adjust your accellerator pump if you havnt. this makes a huge difference.
i also went with lower gearing in the front to make it snappier.
