Engine Teardown Special Tools?
9 replies to this topic
  • ca_101
Posted February 18, 2009 - 11:55 AM
I recently picked up an '00 426, seized up. I got it pretty cheap, that is why I bought it. I already picked up a '02 crank with necessary gears to switch it over, expecting that is the problem. I was just wondering what special tools I will need for this job? I know the shop manual has all kinds of special yami tools, but which do I actually need? I have all of the common tools, and a couple of torque wrenches (smallest is 0-75 ft/lbs). This is the fist yamaha and fist 4-stroke (besides my pit bike) I will be splitting the cases, so just looking for some advice from experience. BTW, I can still turn the engine over with the kicker, but it turns really hard. The guy I picked it up from said it started seizing and he shut it right down. Any comments on the problem or teardown would be great!
  • SXP
Posted February 18, 2009 - 12:04 PM
Two that I can think of: a puller for the flywheel, and a puller to get the left case off the crank. The left case main bearing and left half of the crank have an interference fit that requires a puller to separate them. The right side of the same just drop into each other.
  • GCannon
Posted February 18, 2009 - 03:14 PM
What about a different puller to install the new crank into the left case half?
Posted February 18, 2009 - 04:35 PM
Recommended, but not totally necessary.
  • 642MX
Posted February 18, 2009 - 06:10 PM
A flywheel puller is the only tool really needed if your replacing the crank assembly. YZF cases almost pop apart on there own when all the bolts are removed. I light "love" tap from a rubber hammer and they split right apart.
I have the puller to remove the crank from the case, but a large hammer will also remove it.... (use this method only if your junking the old crank).
  • 642MX
Posted February 18, 2009 - 06:12 PM
Not needed. Freeze the crank assembly and she'll slide right in. :lol:
  • ca_101
Posted February 19, 2009 - 05:16 AM
Yeah, I actually got the "freeze" method advice from a buddy of mine the other day. It's a pretty creative idea.
  • ca_101
Posted February 19, 2009 - 06:39 AM
Would anyone recommend replacing the oil pump or can it be cleaned/conditioned? Does it wear out?
Posted February 19, 2009 - 07:36 AM
Well, it might have been, say over 100 years ago, but it's been around way too long to be considered creative any more. Now it's just an old trick.
  • 642MX
Posted February 19, 2009 - 08:02 AM
The manual shows you how to check it. But, I've never checked them, I just replace both parts (the pump and rotor come as 2 seperate parts) for the piece of mind aspect.
