2008 YZ450 Lowered Footpeg Brackets
16 replies to this topic
  • longie
Posted February 17, 2009 - 04:14 PM
Does anybody make lowered footpeg brackets for YZ450......thnx........
  • mike_dean
Posted February 17, 2009 - 04:49 PM
Fastway made lowered brackets for my '06, but the torx bolts the stk brackets are mounted with wouldn't come out, so I mounted the pegs in the lowboy position and ground down the stop on the peg so it fit the head of the bolt perfectly and at the right angle and it worked great. The Fastway lowered brackets really were only different in that they had tapered head bolts so they mounted flush in the bracket. Mike
  • yama4life07
Posted February 19, 2009 - 11:54 AM
What are the benefits of lowering your footpegs?
  • Smokeslider
Posted February 19, 2009 - 08:32 PM
More cockpit room for bigger/taller folks
  • yama4life07
Posted February 20, 2009 - 08:52 AM
what is the best kit. I am a 6'1 rider.
  • cowboyona426
Posted February 20, 2009 - 09:13 AM
I've heard you can remove the lower bolt, then countersink the hole and buy a new bolt to have the bolt head flush with the bracket, then do the footpeg mod to lower the pegs. Haven't got around to it yet on mine.
  • yama4life07
Posted February 20, 2009 - 10:13 AM
Will that be strong enough cause I am a 2007 with the aluminum frame.
  • mike_dean
Posted February 20, 2009 - 04:50 PM
Let me know how you get the bolt out. The torx bolt barely has any area to grip with the tool, mine wouldn't budge. Mike
  • Demo_Slug
Posted February 20, 2009 - 10:53 PM
you and me both. I tried an impact gun but the bit just jumps out. and I ruined 2 torq bits. :lol:
  • mike_dean
Posted February 21, 2009 - 07:34 AM
Yeah, I used an impact driver and some heat from a propane torch, no luck, I gave up and machined the end of the peg where it contacts the bolt to mate up with the contour of the bolt ( took alot of time) works good. Mike
  • Tonson
Posted February 23, 2009 - 12:55 AM
I was very recently checking out the Fastway footpegs on Pro Moto Billet and although I was looking for my 2009 YZ450 as I'm 6'4". I am sure they have a low boy mount kit for the 2008 YZ. CHeck out www.promotobillet.com for the full range of pegs.
  • cowboyona426
Posted February 23, 2009 - 08:14 AM
Like I mentioned earlier, I haven't done anything on my bike yet. Sounds almost like more trouble than it's worth.
  • DPW
Posted February 23, 2009 - 10:39 AM
wouldn't a taller seat be better then lowering pegs?
  • Demo_Slug
Posted February 24, 2009 - 10:08 AM
Taller seat = higher center of gravity = bad.
Lower foot pegs = less ground clearance = bad.
Pick your poison.
  • mike_dean
Posted February 24, 2009 - 12:14 PM
Pick your poison.
I do both along with up and forward bars, bike is very comfortable, once my bike is modified like this I have a hard time riding a stock bike, footpegs are only 3/8" lower and 3/8" back, grd clearance is not really affected, I think these bikes are set up for somebody about 5'10". Mike
  • Demo_Slug
Posted February 24, 2009 - 01:59 PM
yes it really is affected. the pegs are lower. I’d agree that it is technically not the lowest point on the bike. And they do fold out of the way. But your toe is going to be just that much closer to getting snagged on brush and rocks. I wouldn’t say that lowering the pegs is a bad idea, just that it is not without a downside.
  • Two-Six
Posted February 24, 2009 - 04:59 PM
I run lowered IMS footpegs and love them. I think I got them straight from IMS for 125 bucks, they are wider on lower than the stock 06 pegs.
Motocross
  • Hot  491 replies
  • Hot  28 replies
