1 reply to this topic
Posted February 12, 2003 - 11:35 AM
Can you use A YZF flywheel in A WR? has anyone done this, will the YZF flywheel work with the lighting coil?
  • trailriderjoe
Posted February 12, 2003 - 02:38 PM
No the YZF flywheel is set to a much smaller diameter. To use the YZF you would need to switch also the base plate which holds both the lighting and ignition stators. Of course this kills any hopes of having lights since the YZ base plate only has the ignition stator on it.
