Ideas on how to fill oil on 426... not your average oil change.
16 replies to this topic
  • shawnbassett26
Posted February 15, 2009 - 10:05 AM
Ok will i have my 426 and i have the wet sump kit and a DSP carbon stator cover (with no timing plugs). The only way i can think to put oil in the motor is through the breather tube on the valve cover or take the valve cover off. I wish it had a standard oil fill... Anyone very had this combo?
~Shawn @ BMS
  • ThumperKid250F
Posted February 15, 2009 - 10:34 AM
maybe get a alum. cover then drill and tap a hole in it so you have a fill plug?
  • Zaj 243
Posted February 15, 2009 - 02:43 PM
Won't a funnel with a hose work through your timing plugs (on ignition cover)?
Posted February 15, 2009 - 02:45 PM
... i have ... a DSP carbon stator cover (with no timing plugs).
Read the post.
  • Ogener
Posted February 15, 2009 - 03:45 PM
You could always flip the bike on its top and fill through the drain hole! haha just messin, I think your best bet is through the vent tube or valve cover.
  • shawnbassett26
Posted February 15, 2009 - 05:53 PM
Id like to tap my case, but i think ill just pull the cover... or flip my bike over... If any one has a good idea let me know.
~Shawn @ BMS
  • ThumperKid250F
Posted February 15, 2009 - 08:57 PM
~Shawn @ BMS
that might work but you would have to be very careful drilling. wouldent want it to start to crack... i would also pull the side case off when doing so.
  • USED YZ426F
Posted February 16, 2009 - 07:31 AM
I would just put the oil in through the breather. No need to drill the cases and it only requires taking the tank off when changing the oil.
  • lightestYZF
Posted February 17, 2009 - 06:21 PM
or just lay the bike on right side , remove the ignition cover, pour oil in, replace ignition cover
  • Ogener
Posted February 17, 2009 - 07:39 PM
Would it be possible to add the oil through the oil filter galley? or would the flow into the engine be to slow and tedious?
  • shawnbassett26
Posted February 18, 2009 - 09:00 AM
Laying the bike on its side is not an option, the motor is in a road racing bike and i think that would be more trouble than its worth..... Im just going to full it through the valve cover.
~Shawn @ BMS
  • Brandon Meidam
Posted February 23, 2009 - 09:24 AM
Don't you have the dipstick up top on the frame? I have a 2001 426 and this is where I fill the oil.
Brandon
Posted February 23, 2009 - 09:46 AM
In his first post, he said...
...meaning there is no external oil tank anymore. What he didn't say here was that it's in a custom road race frame, so no, no filler on the frame.
  • ThumperKid250F
Posted February 23, 2009 - 11:12 AM
Brandon
why do you fill the oil where the dip stick is?
  • Wiz636
Posted February 23, 2009 - 11:26 AM
That is where you fill the 426's in stock configuration.
  • ThumperKid250F
Posted February 23, 2009 - 12:53 PM
o i dident no that about the 426s
  • DPW
Posted February 23, 2009 - 04:32 PM
I'd just go buy a stock 426 crankcase cover and fill through the timing plug...carbon fiber is over-rated...;-)
  • 10 replies
  • Hot  47 replies
  • 5 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
