Bog - be - gone: R&D powerbowl
7 replies to this topic
  • Krannie McKranface
Posted February 14, 2009 - 05:09 PM
R&D powerbowl with R&D power pump ,made an immediate improvement in bog reduction and throttle repsonse. Near scared myself to death when I tested a WOT 'whack' in first gear: no bog, just sky! It will still bog if the rpms are low and I 'try' to make it bog, but I haven't even adjusted the leak jet (tried one turn out), the Remote fuel screw (tried 1.5 turns out) or the APump settings (stock on mines seems to be about 1mm, a bit early) yet.
I'm stoked that I can now loft the wheel over a slow obstacle without total fear of 'flame-out'.
:lol:
  • dazzabb
Posted February 14, 2009 - 09:26 PM
Fitted one to my 05 over a year ago and have never had to touch it since.
An immediate - although not a cheap - improvement.
  • 123BigcoopDawg576
Posted February 14, 2009 - 09:52 PM
Krannie
did your 03 carb bowl have a leak jet? if so, a 40 leak and the o-ring mod would have done the same thing...
Posted February 14, 2009 - 11:36 PM
Krannie
Well, I tried the 30 and the 40 leak jet, the single and double o-ring mod, bending the AP spring tighter, and they all helped, but I would still flame out over a simple low rpm wheel lift. With the R&D stuff, it is twice as good, right out of the box. Really noticeable in a power slide: now you can dial in the power you need, instead of trying to deal with the power you get.
It all only cost me $ 129.00 shipped. Gotta love ebay (sometimes).
I will do the AP timing next.
So, what is the hot set-up for the forks? They seem lifeless.
  • Just_a_trail_rider
Posted February 15, 2009 - 08:17 AM
Interesting add-on you got here. I am learning at your expense. I remember you telling me that my bike seemed down on power the last time we rode together. I'm a better rider now so I could use a little snap on the low end. But I like the mellow nature of this beast. I don't want to change that too much.
thanks for the education...
regarding the forks... you've got the 46mm open bath forks. They desperately need to be reworked. I had my 46mm kayaba's on my yz done by Dave @smartperformance who also gave me the full build specs and shim stacks used incase I want to adjust the valving myself in the future. I think he will also sell you the parts and specs to rebuild your own if you want.
Swapping to the 05/06 or 07-up 48mm forks are the next step up. Ebay is your friend :lol: if you go this route.
Posted February 15, 2009 - 10:00 AM
Yeah, you're bike felt very down on power, and it had a big flat-spot on the bottom. It's easy to fix.
Isn't Smartperformance in San Francisco? That seems far to go.
Posted February 15, 2009 - 05:13 PM
I mailed the parts to him for $20. Its was easy.
You could even call Dave and he will ship you the parts necessary to rebuild your own fork and shock. He'll help you though it.
  • erickdj
Posted February 15, 2009 - 06:11 PM
The hot setup is the yz fork swap.:lol:
