Street Legal Makeover
8 replies to this topic
  • mazzuca21366
Posted February 13, 2009 - 06:29 AM
Just did a switch of parts after I got the plate. What a difference in looks.Posted ImagePosted ImagePosted Image
  • thumperyz450f
Posted February 13, 2009 - 08:26 AM
Did that start out as a YZ or WR?
  • mazzuca21366
Posted February 13, 2009 - 09:18 AM
Yz450F
  • JimmyBee
Posted February 13, 2009 - 08:35 PM
Did you have any trouble getting it plated?
  • mazzuca21366
Posted February 14, 2009 - 05:12 AM
No. I recieved my plate and owners card in less than 2 weeks. Just make sure everything you put on the bike is DOT. If you live close to me I can supply the parts for the inspection. I am running a total loss system for the lights, hence the tool bag on the rear fender. I dealt with Carl at Pro Cycle for all the parts. Im running a alarm battery from Interstate Batteries. The headlight will last 1 hour if turned on continuosly. I cruise with the headlight off, therefore I am only running the led tail and the vapor speedo. In this mode I have ridden over 3 hours with still plenty of juice left. Make sur e on your copy for the parts it says dot next to each item. Carl will add that when he prints it out. After you get the tag then custimise the way you like.
  • thumperyz450f
Posted February 14, 2009 - 10:21 AM
So you have to charge the battery every time after you ride? I have an 07 yz450f and i really want to do this to my bike. How much did all the parts cost?
  • yzinger6
Posted February 14, 2009 - 12:05 PM
+1 on more information and links! I will be doing this soon...
  • mazzuca21366
Posted February 14, 2009 - 06:05 PM
http://www.dualsport...skits/dskit.htm I purchased all my parts from Pro Cycle. a 12 volt 5 amp hour. . I ride with the headlight turned off. . I also installed 1 9 pin and 1 2 pin connectors under the seat so I can change out the rear fender for dirt. . The battery is 4 pounds. The cost was $700.00 for everything. That included the dot tires and tubes from Pro Cycle. Kenda Trackmasters.
  • mazzuca21366
Posted February 14, 2009 - 06:17 PM
http://www.interstat...ype|101|1|,N~36 Heres the link for the battery.
  • Hot  38 replies
  • Hot  36 replies
  • Hot  47 replies
  • Hot  50 replies
