Triple clamp torque specs?
6 replies to this topic
  • DrzDasher
Posted February 12, 2009 - 06:27 AM
Installing my forks and I have yet to get a manual. 04 450, was wondering what the torque specs were for the triples, thanks in advance.
  • 123BigcoopDawg576
Posted February 12, 2009 - 07:04 AM
15 ft lbs...i believe
here is a link to your manual
http://www.yamahaown...TJ-28199-41.pdf
  • Krannie McKranface
Posted February 12, 2009 - 01:13 PM
Remember, those are LUBRICATED torque specs. You might break an old dry bolt if you torque to spec, and steel bolts in aluminum corrode, so be careful.
  • CheYuen
Posted February 12, 2009 - 02:50 PM
?? What does this mean? Should I be applying some sort of lube upon reassembly?
  • SJMC_DON
Posted February 12, 2009 - 03:58 PM
17lbs upper 14lbs lower as illustrated above.. (albeit I just do 17 on both (lazy). For years I did not even know what a torque wrench was for!
And yeah, whats a "lubricated torque spec"? :lol:
  • acarter92
Posted February 12, 2009 - 05:33 PM
Put a little dab of grease on the bolts. Especially when using a steel bolt on alluminum or vise versa. It keeps corrosion down. Austin
Posted February 12, 2009 - 08:26 PM
Steel against aluminum causes electrolysis based corrosion. Not treated, it will give you false torque wrench readings, and eventually, seize the bolt.
Any time you remove a bolt that is not going into steel, you need to put anti seize on it. Swingarm chain adjusters are the biggest culprit.
