would my 06yz450 get the same miles pertank as the honda
29 replies to this topic
  • ThumperKid250F
Posted February 11, 2009 - 07:19 AM
im just wondering if my 2006 yz450 would get the same miles pertank as a crf450 2006. reason im asking is because i sold my big tank last year when my bike blew up... my buddy on his honda can almost go a day riding on his stock tank so im wondering if i could make it as far as him?
thanks guys
Posted February 11, 2009 - 07:45 AM
"Your mileage may vary".
Figure about 20-23 mpg for a guess.
  • matt4x4
Posted February 11, 2009 - 08:15 AM
Probably more - some time down the trail - you'll probably pass the honda because it broke down.....
  • ThumperKid250F
Posted February 11, 2009 - 08:19 AM
alright then i think i better get a bigger tank then..
thanks guys
  • DRX350
Posted February 11, 2009 - 08:20 AM
Try closer to 40mpg+. My buddies CRF450R can go over 65miles on a stock tank. A KTM 450 EXC can go 90+ miles on a tank
Posted February 11, 2009 - 09:08 AM
But, it has a larger tank than the 1.8 gallons of the YZ450, and considerably higher gearing. From personal experience with a YZ and the standard tank, a 38 mile trip through the desert riding moderately will leave very little fuel in the tank.
  • DRX350
Posted February 11, 2009 - 09:13 AM
Riding at hard at Ocotillo, a CRF450R can go 75 miles and those have a 1.8/1.9. My buddies 525 KTM with 15-51 can go 85 miles (2.2gal). Cruising through the washes at 50+ and all...
I can get 150 miles to my 3.5 gallons riding moderate, about 135 miles riding hard.
Posted February 11, 2009 - 09:19 AM
That's intriguing, since none of the people riding the desert races I ride can go more than two 25 mile loops without refueling their 3 gallon tanks.
  • DRX350
Posted February 11, 2009 - 09:26 AM
We aren't racing, we're just riding fast and hard. Like about a 6 out of 10 on effort. I know when I go into race mode (8/10 or more) I can run through 3 gallons in 70 miles. But I have a 350 too. The KTM has about a 60 mile range and the Honda has about a 50 mile+ range in go real fast mode.
I was posting figures on an average day in the desert.
Posted February 11, 2009 - 09:35 AM
So was I. On the 38 mile ride, I was taking it somewhat easy to stretch the tank. Neither the KTM nor your 350 have any particular relevance to the fuel consumption of the YZ450 for reasons already cited. It is what it is. It depends a great deal on how the bike is ridden, and varies quite a bit, but 20-23 is still reasonably accurate as a conservative estimate. If one cares to, he can always pack up two liters of fuel and a GPS or trip odo and see how far he can get. Just be sure to stay within range of the two liters after the first 40 miles.
  • DRX350
Posted February 11, 2009 - 09:42 AM
OK, here, a buddy I ride with has a 2002 YZ426 with mods and can get 50 miles to a tank and more if he conserves.
Quite frankly, unless you're racing, 20mpg on a 450 is absurd, you need to tune the carb. When I road raced a 650cc 4cyl (34mm carbs) I got about 20mpg and thats going full throttle for long periods of time most of which is acceleration (which uses more fuel). I also raced autocross which is nothing but acceleration, and my 1600cc engine used 3 gallons in a full day of heats.
Also you mentioned liters, are we talking Kms or miles/ Liters or gallons here? A good way is to put 1 gallon exactly and carry the spare fuel as you mentioned.
Posted February 11, 2009 - 11:05 AM
That fits. 40 miles on a stock 450 tank is realistic under those terms, and a 426 holds 20% more fuel. 50 miles from a 426 pencils out at 22.7 MPG.
When you road raced a 650, you had vastly higher final gearing, as was the case when you autocrossed your car. The stock gearing in a YZ450 produces only 8.4 mph per 1000 RPM. So, when you're happily bouncing along at a comfy 45 mph across the open desert, the engine is spinning at just over 5300 RPM. Quite happily, of course, but that's more than 3600 power strokes per mile, and it still takes more fuel just to turn the engine that fast than it would if it were geared higher.
The 20-23mpg figure was, as I said, a safe number to count on, although you could do worse than that if your ride included a lot of dune climbs, etc. If one is planning on riding to some remote area, it's wise to err on the conservative side until you have established what your bike will do with you on it.
  • DRX350
Posted February 11, 2009 - 11:19 AM
Don't forget to remember that his tank wasn't totally empty either. :banghead:
Houston, we have a problem. That may be true if my 650 was a single, but it fires 2x per revolution and at 100mph-ish it revved 7500 so uhh, yeah 15,000 combustions per minute. Also the final Drive ratio was 3.38:1.:lol:
In autocross the highest average speed is about 30mph, AC is racing in a VERY tight course, my final drive ratio was actually 4.12:1, not a whole lot different than a bike. It too was a 4cyl; so at 4000RPM its firing 4 times as often as a dirt bike.
You are right on the fact that it is better to be safe than sorry, but, I think the best way to solve this is to run 'til empty on a full gallon and see.:worthy:
  • ThumperKid250F
Posted February 11, 2009 - 11:26 AM
ok well thanks for your input guys:thumbsup: yea when we go out woods riding its like were racing the whole time. were going as fast as we can most of the time. so im guessing im going to have to get a bigger tank then.
Posted February 11, 2009 - 11:39 AM
My tank wasn't completely empty after the 38 mile ride either, so what?
A 4 cylinder 650 fires 4 times as often than a single, but each event is one quarter as large. 650 is 650, in one slice or 4. And in fact, a 4 cylinder is more efficient.
Your rear drive ratio may have been 4.12, but you were likely never in 4th gear, meaning that you have to figure in the reduction for second gear (for instance) which was probably something like 1.7:1. That gives you an overall final ratio of 7:1. The overall ratio of the YZ450 in 5th gear is 9.45:1 (rounding), 35% lower.
  • DRX350
Posted February 11, 2009 - 12:06 PM
As a Big tanker too, I'd highly recommend using that foam for the inside. It really works well. That sloshing has thrown me askew more than once.
  • ThumperKid250F
Posted February 11, 2009 - 12:11 PM
really i never really had a problem with the sloshing, in my yz 250 with the big tank, what foam are you talking about?
  • DRX350
Posted February 11, 2009 - 12:18 PM
You like this huh!?
I'm tiring of this, a 4cyl uses more fuel than a single, sorry, no exceptions to the rule.
Ford made a 1.8L V6 a while back that got 23mpg, what does a modern 4cyl 1.8 get; ~40? That's why most passenger cars have eliminated V8s, if a 4 or 6 can produce the same power, they will get better economy than a V8.
Also, on my autocrosser, each piston was 400cc, 87mm bore, It had 2-40mm two barrel carbs and there is no situation in which a dirt bike could use more fuel than a car regardless of gear ratios.
Look at the simple fact of mechanical resistance. A 450cc 4cyl has so many moving parts that it takes more energy (fuel) to keep them reciprocating.
END.>
  • DRX350
Posted February 11, 2009 - 12:21 PM
It's foam that you put inside the tank. IMS sells some, I forget the other brands, but I love it. Especially when the tank is about half full. You don't think there's sloshing occuring until you try the foam.
As a side note; it comes out easy too.
  • ThumperKid250F
Posted February 11, 2009 - 12:26 PM
cool im gunna have to look into it then. maybe ill give it a shot:thumbsup:
  • 5 replies
  • Hot  36 replies
  • Hot  30 replies
