Qestion On WR Models
10 replies to this topic
  • yamahaulerbillh1
Posted February 10, 2003 - 06:43 PM
I was wondering what the bottle is underneath the rear fender behind the left side panel. What is it used for? Thanks for the info :)
  • BEAN329
Posted February 10, 2003 - 07:10 PM
RTFM !!!!
if it looks like AF
smells like AF
well need i say more
  • tk421
Posted February 10, 2003 - 07:13 PM
It’s a reservoir tank to hold coolant.
When the radiator and the coolant gets hot, the coolant expands and it goes into the reservoir tank.
As the coolant cools, it contracts forming a vacuum in the cooling system which draws coolant from the reservoir tank into the cooling system keeping it full.
  • yamahaulerbillh1
Posted February 10, 2003 - 07:14 PM
Thanks for the info.
  • ThumperWR450F
Posted February 11, 2003 - 01:07 AM
  • timvv51
Posted February 11, 2003 - 05:04 PM
Ive heard you can remove it to save weight. Whadayathink. Tim
  • x2smoker
Posted February 11, 2003 - 05:11 PM
You can remove it, YZF doesn't have one. If you do remove it, don't forget to pack a gallon of coolant so you can top off the radiator after every ride. If you ride tight, slow single track, you WILL lose coolant without the resevoir.
  • blue_beast_wins
Posted February 12, 2003 - 01:19 AM
If it's anything like a car, you take off the overflow tank and you have to change the radiator cap to a "non recovery cap"
  • Butta
Posted February 12, 2003 - 09:18 AM
I've had mine removed for almost 1000 miles...no problems. All you have to do is replace the radiator cap with a KX500 cap (1.6 instead of 1.1). I've never lost any coolant due to heating. I lost a little when I went to 14,000 ft in Colorado, but who wouldn't???
Posted February 12, 2003 - 11:26 AM
butta is correct. resivoir is only needed if you are working the motor at slow speeds
  • timvv51
Posted February 12, 2003 - 05:36 PM
I am an X XR650R owner and we always used a little water wetter in the coolant. Would this not be a good idea for the WR450 also. Tim
