Front sprocket nut
11 replies to this topic
  • durzer
Posted February 09, 2009 - 10:59 AM
Can't budge it!
Applied some heat of small torch, back brake on and wedged against the wall with an extended socket wrench and nothing budges.
It is a normal thread and not a left handed thread isn't it?
Gonna have to get a grinder on it otherwise :)
  • WR450FGreg
Posted February 09, 2009 - 11:06 AM
No, it's your run-of-the-mill right handed thread nut.
Got an impact driver?
Better still a rattle-gun (air impact driver).
They should loosen it.
  • acarter92
Posted February 09, 2009 - 12:40 PM
Lots of leverage and some WD-40 should get it loose, or an impact wrench as said above, if that don't get it off then break out the grinder.
  • TRUE_2_YAMAHA_001
Posted February 09, 2009 - 01:31 PM
soak it in wd-40 and a breaker bar. (if impact doesn't work)
i would try that before you broke out the grinder.
Posted February 09, 2009 - 02:11 PM
Rattle Gun (Impact gun) I have a Milwaukee electric one and it is by far one of the most used tools I have.... not on the bike much but just had to replace hubs on the truck this weekend and the job took half the time with it:thumbsup:
Anyway, a rattle gun will have that nut off in about 2.5 seconds:ride:
  • WR450FGreg
Posted February 09, 2009 - 11:03 PM
I'm with you Don.
I reckon my rattle gun was the best $100 I ever spent.
Man, does it save some heartache!
  • dl19
Posted February 22, 2009 - 05:24 PM
Don't use WD-40. Glazes and creates a mess in the future. Use JB Blaster or Kroil and let it soak over night. Impact gun will take it right off. Should never need to grind it off. Anti-seize it back on and you should never have a problem in the future.
  • nitronaf
Posted February 22, 2009 - 07:26 PM
I just put the bike in gear get on the right side hold the rear brake down with a foot. Reach over the bike with a breaker bar and a 3 foot pole and she comes off real easy
  • TRUE_2_YAMAHA_001
Posted April 02, 2009 - 08:40 PM
use wd-40 it will get into the threads and loosen up whatever is holding it in. works fro rusted bolts too
  • doctorchopper
Posted April 03, 2009 - 04:51 AM
you would be better off using a penetrating oil rather than wd-40. Wd-40 is not a penetrating oil the wd stands for water displacement. Soak it over night and get it nice and hot with a heat gun, not a torch, someone probably put red threadlock on it.
  • Summit
Posted April 03, 2009 - 06:54 AM
I agree, wd is not bad but a real penetrating oil just works better.
  • ARyder
Posted April 03, 2009 - 09:34 AM
Isn't there a locking tab on the washer behind the nut that is folder over onto the nut to keep it from moving. If this wasn't straightened the nut isn't going anywhere.
Just a thought...on my 636 I forgot out this tab and after bending it back, the electric impact got it off very quickly.
