Starter bearing in flywheel
2 replies to this topic
  • hillclimbguy
Posted February 08, 2009 - 08:56 PM
Has anybody replaced starter bearing in flywheel? Going to attempt this week.
Starter wont engage. Found rollers to be worn.
  • PBDBLUE
Posted February 09, 2009 - 06:52 PM
I think you're referring to the starter clutch. You'll need a puller to take the flywheel off. Then just remove the 6 bolts holding the clutch on. Clean everything up and use loctite when you put the new one on.
  • hillclimbguy
Posted February 09, 2009 - 08:27 PM
Thanks for the reply. I have the puller. Just didnt know about the starter clutch.
Again thank you.
