Rekluse left hand rear brake and 2 finger clutch with Baja Designs dual sport?
5 replies to this topic
  • davidwaters
Posted February 08, 2009 - 05:23 PM
Anyone successfully used both the Rekluse left hand rear brake/2 finger clutch with the Baja Designs dual sport kit? I just tried and the levers seriously interfere with the switch assembly. Anyone gotten around this?
https://www.bajadesi...switchpanel.jpg
Is there a low profile switch assembly that I could swap in?
  • Krannie McKranface
Posted February 08, 2009 - 05:53 PM
There are a few lower profile switch clusters (dsa.com), but if you adjust the break (or clutch) lever, you will not need to pull all the way in. That is what I do for my clutch lever, which hits the cluster.
  • davidwaters
Posted February 08, 2009 - 06:00 PM
Could you post a pic of your handlebar setup? I couldn't find a way to get it mounted. I was either going to hit it the switch with the brake lever or clutch lever. The best way I could get it mounted, it would probably kill the bike with a good clutch pull (hit the kill switch).
Posted February 08, 2009 - 06:56 PM
SURE: HERE YOU GO:
  • davidwaters
Posted February 09, 2009 - 03:29 PM
Oh, I thought you had the Rekluse left hand rear brake and 2 finger override setup. There isn't nearly that much clearance with the new levers that I have... Not even close.
Posted February 11, 2009 - 02:51 AM
You mean you have a clutch lever and a break lever on the left? Everyone I know that has tried that has taken it off, and gone with either the clutch only or the brake only on the left.
