Need brake upgrade advice for '90 XR600R!
1 reply to this topic
  • czeddie
Posted February 09, 2003 - 07:39 PM
Guy's, the 1990 Honda XR600R is on a budget and I need new front and rear brakes!!!!
The rear brakes will be upgraded to only new pads.
The front brakes though, well I'm going to set a $100 budget for it in parts only (i do the labor).
I'm a very aggressive street-only rider here in Malibu, CA.
What can you recommend? The brakes are stock!
I know I can get premium pads for the front, but I think I'd like to know what else I can do for cheap.
Maybe find a used brake setup from a newer XR or CR?
What should I do?
Thanks!
  • Matt96xr6
Posted February 11, 2003 - 07:15 PM
Really the brakes are pretty good on the front of the XR600s. You can upgrade to a more aggressive pad compound to help the stopping distances. If you want a better feel, then just upgrade the stock brake line to a SS (stainless Steel) unit. That helps with the feel a LOT!
other than that, BRAKING products does make an oversized rotor kit for the bike. You can find them on Ebay for like $100 sometimes.
  • 4 replies
  • 9 replies
  • 3 replies
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
