Blue button make me blue in the face.
9 replies to this topic
  • kywr450r
Posted February 09, 2003 - 08:53 AM
Just got my WR450 a few days ago. Everything is working as advertised except the e-start. It has been 30-40 degrees since I got the bike. If I pull the cold start starts right up on the first or second kick. However, whenever I try use the e-start... it seems like it does have enough power to start the the bike..floods..and fouls. The e-start seems to only work when the bike has been running for 5-10 minutes or so. Has anyone else had this problem? One one side of the coin, I am very impressed with how easy it starts with the manual a 250cc 2-smoker. On the other side of the coin, I'm not very impressed with the blue button.
  • xr600r
Posted February 09, 2003 - 10:26 AM
the last time i tried to start mine , it was about 20 out in the garage. it wouldnt start with the button, but it did when i kicked it. i havent done anything to mine yet,
but everybody on here says once you get the jetting richened up, that helps a great deal.
  • Jim_Patterson
Posted February 09, 2003 - 10:40 AM
Give your battery a real long TRICKLE charge. That did it for me. I also found , like someones post a while back, turn your gas on and lay the bike over on its left side @ 45 degrees 1 or 2 times until gas comes out of the carb tube. This speeds up initial startups.
  • Ridin'_MD
Posted February 09, 2003 - 10:55 AM
You guys need to move down to warm and sunny Southern California - 73 degrees with bright sunny skies. That'll be your problem. :)
  • DennisT450
Posted February 09, 2003 - 02:00 PM
Mine does the same thing. Won't start with the button. Kick it a couple time and starts fine. I also noted that when it was warm it would'nt start in gear(w clutch pulled in). Had to shift to neutral. Thought it might be me as this is my first 4-stroke.
  • Dan_Lorenze
Posted February 09, 2003 - 04:34 PM
My bike does the same thing.. This morning it was 30 degrees in the desert and the starter really didn't want to start the bike. I figure if the bike won't start up within 10 seconds you have a dead battery.. It charges fast and will restart the bike perfect after the bike's warm, but you're right, early in the morning I think I'm going to kick it from the get-go (which is really easy). I'm sure these bikes have just enough cold cranking amps in the batteries to turn the motor over a couple of times and that's it. Jim gave some good advise too....Leaning the bike over does help..
  • utvols
Posted February 09, 2003 - 08:38 PM
Dont feel bad, KTM, Suzuki and any other modern e-start bike I have ridden hate the cold. Time on the bike and good jetting seem to help but I just try for a few seconds then whip out the kick start. The bikes do start fine when warm.
  • endurodog
Posted February 09, 2003 - 09:08 PM
Unfortunatly I don't have the little magic button, but I thought someone on here posted that the manual said something about the e-button was suppose to be only for when it is warmed up. If I remember correctly, which I don't very often
Posted February 10, 2003 - 04:42 AM
All right you crazy dogs. I don't have a Yamaha but I do have a KTM and mine works every time. Here's what I do.
1. Think of it like an old carburated car, pump the gas a couple of times and then start. I pull the choke and give the throttle a couple of twists. Then I hit the button and wham-o it starts even when cold out. How ever I do use a trickle charger, the cold robs any battery of power car,motorcycle or what ever. I would first try giving the throttle one twist and see if that helps.
  • law_boy
Posted February 10, 2003 - 10:31 AM
I have the same problem for the first start of the day. However, always starts right with first kick and then e-starts no problem after that.
