2000 yzf 426 Head light
3 replies to this topic
  • yamayota
Posted February 02, 2009 - 10:20 PM
i heading to pismo in two weeks...i need to wire a light..is there a way to wire it in the stock wiring harness?
  • bluebreadtruck
Posted February 03, 2009 - 05:38 AM
I thought yzfs did not have a lighting coil?
  • matt4x4
Posted February 03, 2009 - 05:55 AM
you definitely need a proper stator first unless you can run one with LED's - they require next to no current and it would work fine off a YZF coil.
If you buy a UFO or Acerbis headlight/front plate assy. that runs 2 MR16 12V Halogen Light bulbs, there are places around that sell 12V LED MR16 retrofit bulbs which use little to no current (50mA or so) since the halogens would draw way too much.
http://www.superbrig...ecs/MR16-W4.htm
Usually 20-30 bucks a bulb.
If the bike doesn't have a regulator - you can either build one or buy one for about another 20 bucks.
  • tntmo
Posted February 03, 2009 - 01:48 PM
Have you run those LED lights? How bright are they?
