Valve check on 07 wr450
8 replies to this topic
  • Blackmax
Posted February 01, 2009 - 10:26 AM
I've decided to do the valve check myself and have taken most everything off. Do I need to take off the two engine mounts on the top ?
  • Blackmax
Posted February 01, 2009 - 12:20 PM
Hey guys, I had to use a bar but I was able to get the bolts off. I have no idea why the mounts were put on so tight. Maybe the mechanic who did the last valve check for me used air.
  • brad the best
Posted February 01, 2009 - 01:42 PM
they probably had some loctight on them , or the old alluminum vs steel = fusion .
i usually put never seize on those bolts , never had them come loose .
  • JSanfilippo
Posted February 01, 2009 - 11:32 PM
There should be a white chalky substance on the threads of the bolts.
The first time I removed the mounts it took alot of effort. Even torqued to spec it took alot of effort the second time. I'm convinced its the white chalky substance on the threads.
  • brad the best
Posted February 01, 2009 - 11:52 PM
the white chalky stuff is the zinc coating off the bolts corroding in the aluminum unlike metals tend to fuse together .
  • Blackmax
Posted February 02, 2009 - 09:31 AM
Yes, there is a lot of the white stuff on the bolts. I will put a bit of neversieze on them. Could you guys tell me what sealent you use on the head cover gasket? Maybe R.T.V. silicone ? And the good news is my valves are all within spec. :)
  • 123BigcoopDawg576
Posted February 02, 2009 - 10:36 AM
i dont put anything on mine
this suprised you :lol: dude its a yamaha :lol: :lol:
  • JSanfilippo
Posted February 02, 2009 - 02:47 PM
:lol:
The next time I have the bike appart anti seize is going on them bolts :)
The valve cover gasket is good to go. Just torque the bolts to spec and it'll seal properly!
  • hillclimbguy
Posted February 02, 2009 - 09:30 PM
This will be probably the only time you check your valves. Mine are still in spec after two years. I checked a year ago.
By a honda if you want to adjust valves or change them often. : )
