Hard to start 2006 CRF450
6 replies to this topic
  • chrisbradley44
Posted February 01, 2009 - 05:56 AM
My 2006 CRF450 is a pain to start the 1st time of the day. Jetting is stock, fuel screw is stock and engine only has 10 hours on it so no valve issues. Any ideas? Or any special starting procedures do the trick?
Also a friend has a 2008 CRF250 and 2009 CRF 250 and they both are a pain to start also....all three bikes start fine when warm. We are in Atlanta 500-1000ft.
  • crf-f crf-r trx cbr
Posted February 01, 2009 - 06:00 AM
ummmm temperature?
  • chrisbradley44
Posted February 01, 2009 - 06:12 AM
its been 45-55 degrees out in the morning when we are starting up. The colder it is the worse it seems. None of us had problems with previous bikes...non of the previous bikes were Hondas.
Posted February 01, 2009 - 06:25 AM
wouldnt say it's a problem......it's jetting......try backing out the fuel screw 1/2 turn and using the search feature.....hope that helps
  • Mike_socal
Posted February 01, 2009 - 08:21 AM
Check your decompressor setting. Make sure it's dead on or run a little tighter .023 ish. Measuring with one gauge on the valve shim and one in the decompressor is usually the best way.
  • Dino 615
Posted February 01, 2009 - 08:54 AM
When it's cooler out I just hit the throttle 6 or 7 times, even with the choke on, before I try to start it. When the cylinder is cold the the initial fuel that goes into the cylinder vaporizes and sticks to the cylinder walls so it does not want to combust. By hitting the throttle a few extra times I alleviating this problem by adding the fuel in manually rather than getting a little every time I kick the bike. If it's really cold I usually have to do that, kick it a couple times, then do it again and it fires right up. After that it starts first kick, very easily, the rest of the day.
  • mostoyzwinz
Posted February 23, 2009 - 07:56 PM
Try what I have to do. Give it 2-3 squirts, kick it through slowly for 2-3 kicks to suck in some fuel. Then slowly kick is just past TDC on the compression stroke, give it a squirt, ensure the kickstarter is all the way up (you might have to bump it a little to get that last 'click up'), give it one more squire and a hard swift kick. If everything is set right, it'll fire. This works for me when the temps are down into the 20's F.
Then again, when the valve wear to a no clearance condition, I'm SOL...but with 10 hrs you're right, it shouldn't be a problem for you.
My '05 CRF450R has 'starting characteristics' that change a bit over time.
Good Luck
My brothers 450 by Emkjr93
Dirt Bike   Make / Model Specific   Honda   CRF450R
  • Hot  58 replies
450r trail/enduro by jblob
  • Hot  123 replies
06 Crf450R no spark replaced everything by dirtkid254
  • 11 replies
2017 crf450r by Mcclain210
  • Hot  224 replies
Honda oil help by dirtlife1990
  • Hot  69 replies
