is the stroke the same on a 98 yz400f as a yz450f?
5 replies to this topic
  • yz400fsmasher
Posted January 30, 2009 - 05:36 PM
im asking this because i wanna get a big bore kit for my 400f and i cant find one anywhere but see them for the 450f all the time. if anyone knows let me know.
  • 02WR426Cali
Posted January 30, 2009 - 06:35 PM
Get a 426 crank, then check out LukesRacing.com and look into their 444 kit. Several people on here have nothing but praise to say about the kit.
  • bluebreadtruck
Posted January 30, 2009 - 08:19 PM
no, the 450 has a longer stroke and a different size wristpin....and im told there are other differences in the crank. For me, Im just looking for a 450 engine to swap!
  • DeeCee
Posted January 31, 2009 - 12:56 AM
Another advantage of the 426 crank swap is the piston pin size is bigger and hence better reliability if you add a larger bore piston.
  • Birdy426
Posted January 31, 2009 - 10:52 PM
Try Lukes and Eric Gorr for big bore kits. I believe the 400 punches out to only 420 cc's. As posted above, you can get a 426 crank (with larger wrist pin) and get out to 444. I love mine. Note that if you do that, you will need to get a new primary drive gear as well...
  • yz400fsmasher
Posted February 02, 2009 - 09:47 AM
thanks for the info.
  • 5 replies
  • Hot  36 replies
  • Hot  47 replies
  • 9 replies
  • Hot  79 replies
