so i searched extensively... q on 426 flooding..
11 replies to this topic
  • motarded426
Posted January 29, 2009 - 06:33 PM
had the bike for about a week, absolutely NO problem starting it until today. Tried starting it today for a while, no avail.. did the usual drill/procedure of starting it and nothing..
i searched the forum archives extensively on how to start, but that's not what i'm concerned with.. How can i get this thing un-flooded? is there such a thing?
thanks for helping a n00b.:banana:
-nick
  • 642MX
Posted January 29, 2009 - 08:19 PM
Flooding them is easy to do. Replace the plug and it will probably fire right up.
Posted January 29, 2009 - 08:43 PM
Flooding is easily cleared by several slower kicks through while holding the throttle and compression release both open.
Fouling is only correctable by changing/cleaning the plug, like the man said.
  • motarded426
Posted January 29, 2009 - 09:16 PM
I'll give it a few trys with throttle/compression open; fuel off i assume. Then just go ahead and do the same ol drill to start?
If that doesn't work, i'll go and change the plug tomorrow...
Thanks for the response, i'm a bit technically slow!:banana:
  • motarded426
Posted January 29, 2009 - 09:18 PM
thanks, if i can't get it right with the throttle, plug replacing time!:banana:
  • motarded426
Posted January 30, 2009 - 10:19 AM
thanks for the advice guys... changed the plug out this morning and she kicked right over.... l feel a little 'duh' right now...
  • 642MX
Posted January 30, 2009 - 10:36 AM
Don't feel bad, we've all been there. Remember to completely warm up your bike everytime you start it. YZF's seem to gas foul plugs really easy when they don't get completely warm before shutting them off. (Treat them kind of like a 2 stroke).
Posted January 30, 2009 - 11:10 AM
This is true, but not so much of the YZ450's. The '03 and later had a considerably stronger ignition secondary than the 400/426 did, and are less prone to this. Not impervious, just less prone.
  • 642MX
Posted January 30, 2009 - 11:39 AM
As does the 03 and up 250F. I guess there is something to the coil in the cap ignitions?...
  • motarded426
Posted January 30, 2009 - 12:22 PM
for sure! thanks for the advice!:banana:
  • 642MX
Posted January 30, 2009 - 01:30 PM
for sure! thanks for the advice!:lol:
Your welcome. :banana:
Posted January 30, 2009 - 02:20 PM
There is, but I doubt it has to do with the configuration as much as simple electrical strength.
  • Hot  47 replies
  • Hot  36 replies
  • Hot  33 replies
