Big Bore YZ450f?
8 replies to this topic
  • tnat1
Posted January 29, 2009 - 06:31 AM
I was wondering if anyone knows anything about the Athena 485cc Big bore kits for the YZ450f 2006, Are they reliable, how much HP? Would i need a bigger carb?
  • LEMMON1
Posted January 29, 2009 - 12:53 PM
u really need that much more power?
if thats a case i wold just say ktm505
  • erickdj
Posted January 29, 2009 - 03:55 PM
going by his avatar picture, he might want it for supermoto, so he might need the power for that. Or he might be a big boy that needs lots of power to haul him around. The best thing about a big bore yz vs. the ktm, is that you're not stuck with a ktm.:banana:
Posted January 29, 2009 - 04:09 PM
He might just like overall effect that displacement has on things.
  • jonova
Posted January 30, 2009 - 09:59 AM
I don't recommend doing big bores unless you are a motarder. I have done them all to my previous bikes and found that the longevity of the motor goes down. Train a bit harder, dial in your suspension and ride more, you will get faster.
But if you do, go with thumper racing. They have great quality stuff.
  • cheeta
Posted February 16, 2009 - 09:19 PM
i got an 05 with an athena 478 kit, hot rods crank an TLR performance ported and polished my head for top end along with a valve job. the athena piston fit the yamaha crank but not the hot rods, had to get the piston machined down.
  • barry450
Posted February 16, 2009 - 11:13 PM
What way did you have to machine the crank piston?
A WR/YZ crank uses a 18mm wrist pin where a YFZ Quad crank uses a 20mm wrist pin. Is it possible the HR crank you got was for YFZ?
And I am unsure how a big bore would affect the reliability of an engine, I have never seen evidence of this. What I find is most do more at the same time, like cams/headwork etc and then rev it harder. I see no reason going up in capacity slightly would make anything less reliable.
I am currently building an 05 WR with YZ cams, big valve head, Athena 480, JE 13:1 piston, bored out carb. Will let you all know how it goes.
  • cheeta
Posted February 17, 2009 - 07:43 PM
the wrist pin fit fine, it was the part of the connecting rod that was hitting the underside of the piston. this had to be a machining mistake by hot rods and when i called them to tell them, they said that it was probably the piston. I told them that the piston fit on the stock connecting rod and they stuck 2 their story. the hot rods crank was supposed to be to factory specs, apparently not.
the thing i noticed most about the big bore was it improved my throttle response, but when u get into the revs the bike screams and i cant stop grinning. the head work is awesome. i did send my carb out with my head and TLR flowed them together and i havent had to touch the jetting, but florida is all pretty much the same elevation.
good luck with it, keep us posted. interested 2 know how she runs
  • camman
Posted February 20, 2009 - 12:29 PM
You must slightly increase the rod small end when using a bronze bushing. The Hot Rods will always clear the OE piston. The Athena crown thickness must be greater than OE. Never heard this problem with CP, Wiseco, or Vertex.
  • Hot  50 replies
  • 10 replies
