WR450...steering head bearings..and shock linkage
5 replies to this topic
  • xr600r
Posted February 06, 2003 - 05:50 PM
has anybody had their steering head bearings out, and shock linkage apart to grease things up yet ? if so, were they very well greased from the factory ? thanx.
  • xr600r
Posted February 06, 2003 - 06:06 PM
one other thing.....it says in the manual, the linkage has
"polylube" bearings, that dont need greasing. is this good stuff ? i'm new to the WR camp....and clueless. :)
  • Superbike
Posted February 06, 2003 - 07:00 PM
I do not know about the poly lube bearings. I plan to lube mine regardless. Unless Yamaha changed how they lube stuff, which I doubt. I rode my 2000 YZ for a couple months before I greased it and ruined some of the bearings. It is worth the headache ten fold. The head bearings are very important. Have you messed with the jetting? Have you been ripping it up?----Mike
  • yamaha.dude
Posted February 06, 2003 - 07:47 PM
The polyLube stuff is the yellow String Cheese they use to hold the bearings in place... I would agree it doesn't need replacing, that is unless you actually ride your bike and get water and dirt near the sealls... once that stuff works it way in, then it will degrade the bearings... power washing is a no-no... but even a garden hose can force dirt past the seals...
To be safe and sure, then just do it and keep it up once or twice a year... disassembly to grease it all up gives you the chance to inspect the bearings and make sure they are still in good condition...
  • wrooster
Posted February 06, 2003 - 08:33 PM
accrued maintanence tips -->
linkage procedure
steering stem procedure
some other good info
wheel bearing removal hints
grease floatsam
finally, how to get divorced...
jim aka the wrooster
'01 wr250f
  • Boozer502
Posted February 06, 2003 - 08:52 PM
My steering stem was dry on the bottom bearing
