GREY WIRE where is the plug cant seem to find it
5 replies to this topic
  • SOW1
Posted February 06, 2003 - 03:27 PM
Where do I unplug the grey wire or do I cut it ? I am only able to find a multi pin connector is there a grey only plug?
  • timvv51
Posted February 06, 2003 - 06:59 PM
Yes inquiring minds want to know, please. Tim
  • mwbailey
Posted February 06, 2003 - 07:36 PM
well if you cut you cant go back where if you unplug it and tape it off you can return it to stock if nessaary in the future
  • ryme
Posted February 08, 2003 - 04:14 AM
I had a hard time pulling the gray wire out of the plug, so I just cut it. If I need to put it back for some reason I could just use an in-line splice and throw some heat shrink around it. How do you get the gray wire out without cutting it?
  • tctrailrider
Posted February 08, 2003 - 04:30 AM
Check this out.
This site is for the WR250 but the information also applies to the WR4--.
  • rockieman
Posted February 08, 2003 - 07:02 AM
After you undo the connector plug....I can't remember if it was the male or female side....inside the plug there's a little tab that you need to hold down with a small screwdriver....this is when you need a third hand...your two, to hold the connector and the tab down and in my wife's hand to pull the wire out the back side of the connector.
