Rear Shock Leaking - What are my options
10 replies to this topic
  • locorider
Posted January 25, 2009 - 06:55 AM
Hi. I have noticed a couple of drops of oil on the trailer under the rear shock after our last couple of rides.
What are my options here.
Is this something I can service myself ?
If so would I need any special tools ?
Where can I find a procedure on doing it ?
Thanks.
  • yamaha 422
Posted January 25, 2009 - 06:58 AM
I would not attempt it myself. I don't like a spring shooting at me with all that pressure. I sent mine to Factory Connection
  • gregory25
Posted January 25, 2009 - 07:21 AM
It sounds like you have a bad shock seal, if you have no training in rear shock rebuilding i would send it out to be repaired.
  • nickeenoo
Posted January 25, 2009 - 08:13 AM
You guys crack me up; next you're gonna say the sky is falling or something like that. It's a rear shock not a bomb.
If you have reasonable mechanical skills follow these instructions from Dave J at Smart Performance and you should be fine. If you don't have any skills then you probably should send it out.
Also note that the pressure setting Dave recommends are for use with his fluid only. If you use a conventional fluid fill the pressure to manufacturer specs. Also remember to write down your settings before you tear it all apart.
http://smartperforma...HOCKREBUILD.htm
  • locorider
Posted January 25, 2009 - 12:07 PM
Thanks. Any good places to buy the parts needed, seal etc.
For the guys that do send it in, how much does a rebuild typically run ?
  • Zaj 243
Posted January 25, 2009 - 03:33 PM
If you can rebuild it yourself, go to your local shop and get a moose racing complete seal head. I think they run 30-40 bucks, but its a drop on seal head and the quality seems great for all the ones i've installed. If you send it out be prepared to spend in excess of $100 + shipping. Shocks aren't hard to rebuild, but it is very important to take your time to get all the air out upon reassembly.
  • locorider
Posted January 25, 2009 - 03:45 PM
Thanks.
How about one of these kits, does it have everything I will need or do I still need to buy a seal head ?
http://www.oemcycle....m/product/5669/
  • locorider
Posted January 25, 2009 - 03:48 PM
Sorry for the quick blurbs, but where can I get the nitrogen canister refilled ? Anybody have an idea what that costs ?
I am going to try this myself, just trying to make sure I have all the bases covered.
  • Zaj 243
Posted January 25, 2009 - 04:01 PM
That kit would work, I'm not sure what year your bike is but bladders don't usually need replacing very often. That kit gives you the bushing and seal that install in the stock seal head, and they can be a pain to remove and replace. The moose unit is cheaper, your local shop should be able to get it next day, and it pre-assembled, just slide it over the shock shaft and re-install your shim stacks. Getting it recharged should be as easy as taking it to a decent bike repair shop, it only takes a minute to do. Some welding supply shops also have nitrogen and can charge it to the level needed.
  • locorider
Posted January 25, 2009 - 04:05 PM
Is this the moose unit I need ?
http://www.oemcycle....C_450FE-E_03-04
If I don't need the rest then I will just go with this and call it a day.
Thanks for all the help. I am mechanically inclined, have just never done a rear shock.
Edit- the bike is an 04
  • Zaj 243
Posted January 25, 2009 - 04:50 PM
yep thats the kit, i think that would be the way to go for you. Make sure you check the chrome on the shock shaft for dents, chips, or gouges. Any sharp edges can tear the seal causing a leak, but seals also can just plain wear out, especially if your shock hasn't been serviced in its 5 years of use.
  • Hot  113 replies
  • Hot  47 replies
  • Hot  36 replies
  • 5 replies
  • 10 replies
