Losing Oil!!
4 replies to this topic
  • jbowen13
Posted January 24, 2009 - 08:43 PM
-Just wondering if anyone had experienced this sort of thing. Today I went riding quite a bit, I probably put at least 2 hrs on the bike mostly on a mx track. It was really cold today, like 15F, and when I started the bike it was burning quite a bit of oil for like 30 seconds. Which I had never noticed before, but it went away so I rode all day anyway. I just got back home and checked the oil and am near the bottom X on the stick. I just changed the oil last night and it was on the top line. Did it burn that much oil? And should I be worried?? Thanks ahead of time guys.
EDIT: Oh, its an 06 YZ450... less than 15 hrs on top end.
  • 426 NOOB
Posted January 24, 2009 - 09:23 PM
ok, so this could be a number of things. first: are you sure that it was oil smoke, and not just because it was cold outside? Second: if it was oil smoke, usually when it burns oil at startup, then goes away it is valve guides leaking. Third: if it wasnt oil smoke, the oil could have been blown out the crankcase breather tube. Did you run it hard?
  • jbowen13
Posted January 24, 2009 - 10:50 PM
well, It was oil smoke for sure (blue tint), but it only lasted for like 15 seconds or maybe a little longer. I did run it pretty hard, but im only a mediocre b rider, so its not like I was riding it to its limits. I never though of the breather tube... huh. It doesn't smoke at all if I start it in the heated shop. So should i even worry about this or ignore it??
  • 426 NOOB
Posted January 25, 2009 - 05:12 PM
personally, with the symptoms you described, I would just ignore it, unless you notice it getting worse.
  • jbowen13
Posted January 25, 2009 - 07:00 PM
I will definitely keep an eye on it.. im kinda new to the thumpers coming from a 03 cr250 smoker (well i guess now they both smoke).. haha. Just didn't want to screw something up and ruin the bottom end via catastrophic failure or something. Thanks.
  • Hot  36 replies
  • Hot  38 replies
  • Hot  113 replies
  • 0 replies
  • Hot  50 replies
