Carby Swap (426 into 400)
3 replies to this topic
  • jdswr
Posted January 22, 2009 - 05:47 PM
Hi Peoples
Im hoping sombody can help me with this
I have a WR400F (2000) with a worn carby needle carrier :banana: i have priced this part and is $580.00 from the Stealership or AU$465 from the ttshop
i have also been chasing the local bike wreckers and have found a 01 wr426 complete carby which is in mint condition for $450
i was just wondering if this carby would fit and not cause any performance issues besides the obvoius jetting issues which i will have to sort out
any help would be greatly appreciated
JD
  • ncampion
Posted January 22, 2009 - 07:58 PM
Don't see why it wouldn't work fine, you even get the Gen !! carb so should not have the cracking slide plate problems.
  • Birdy426
Posted January 22, 2009 - 09:55 PM
It will work better than the Gen 1. You will have to cap off the vacum port on the l/h side of the intake tract that provides vacuum to the hot start octopus, as the Gen 2 carb has the hot start circuit internal to the carb.
  • jdswr
Posted January 24, 2009 - 03:33 AM
Cool Looks like ill be going shopping
Thanks for the advice guys
JD:thumbsup:
