Why 2 cams?
9 replies to this topic
  • Math
Posted February 05, 2003 - 05:05 PM
I was discussing about mechanic with my buddy few days ago and we were asking ourselves:" Why 2 cams?"
We understand easily why the overhead cam, we understand why 4 valves or even 5 instead of 2 but why is it more efficient to put them under the control of different cams ???
Thank you
  • Superbike
Posted February 05, 2003 - 05:13 PM
It eliminates the need for rocker arms. It also keeps the valve angle straighter that it would be with one cam and a shim and bucket system. The key is it is simpiler. ---Mike
  • Math
Posted February 05, 2003 - 05:25 PM
Cool!! :)
Thanks again! :D
  • yamaha.dude
Posted February 05, 2003 - 06:00 PM
direct cam to valve contact allows them to rev so high, and to still be reliable... less to break, less to adjust, less weight to spin around...
  • Dwight_Rudder
Posted February 05, 2003 - 07:54 PM
It does allow more RPM but who needs that many R's on a dirtbike. DOHC is also much heavier than a SOHC. It also is much harder to adjust the valves although you don't have to quite as much.
  • DesertChris
Posted February 06, 2003 - 01:12 PM
In addition to the reasons listed above there is also advantages with being able to make split lift/duration and timing between intake and exhaust that is not as easily done with a single cam.
  • beezer
Posted February 06, 2003 - 03:20 PM
Math, for all this good information we Americans are giving you please PM some profanity to use while I'm driving in Quebec.
I'll be up there next Fall and I don't want to go unarmed. :)
  • Math
Posted February 06, 2003 - 03:35 PM
Thanks to all of you for these explanations...
Hey Beez, Don't want you Americans to come here to blast us!!! :D :D
But man, are you crazy :D, why do you want to come in Québec in fall :D....You'd better buy yourself a good winter coat!! :D :D
  • beezer
Posted February 06, 2003 - 04:10 PM
I can handle it buddy, I've hunted in SK in December. :)
  • Dwight_Rudder
Posted February 06, 2003 - 08:24 PM
That is part of the RPM thing. I want the easier to maintain and lighter SOHC setup. I think somewhere down the road someone will come up with a good pushrod setup. Lower CG , Less head heat.
