Stripped out radiator shroud
2 replies to this topic
  • tgrant
Posted January 21, 2009 - 07:29 PM
The 8mm bolt on my radiator shroud spins freely inside the fuel tank. I'm trying to replace the radiator and am unable to remove the shroud. The bushing embedded in the fuel tank spins freely with the bolt. Has anyone else had this problem, and if so is there an easy fix? Thanks
  • Rivervalleyrider
Posted January 21, 2009 - 07:34 PM
You are better off to just pull the bushing out of the mount and then epoxy it back in and let it dry before you mount the shroud. Thats what i would do.
  • tgrant
Posted January 21, 2009 - 07:38 PM
Thanks, I'll give it a shot.
