kick starting !!
13 replies to this topic
  • ThumperWR450F
Posted February 05, 2003 - 01:47 PM
anyone having trouble kickstarting there wr450's? kick starting seems to be getting worse as the bike breaks in. the first day i got it ,it started up on first kick. now it takes like 10 if not more to start it. do you think i should go up to a 72 starter jet ? once the bike runs and i stop it ,i push the e-start and she starts right up. i think it has alot to do with it being cold and the fact i hadn't ridden it in a few days. any suggestions guys?
  • utvols
Posted February 05, 2003 - 03:48 PM
What jetting and mods have you done? My bike kicks over easier than any for stroke I have ever owned.
  • ThumperWR450F
Posted February 05, 2003 - 04:02 PM
160 main 48 pilot ,snorkle and baffle removed.
  • utvols
Posted February 05, 2003 - 04:16 PM
Read some of the post on jetting and play around with the fuel screw setting. Also are there ever any strange grinding noises or hicup type backfires when you use e-start? If so it is probally a good idea to check your woodruff key. I chased my tail for two weeks with jetting and starting issues before finding out my bikes timing was off from flywheel spun on broken woodruff key.
  • brebro
Posted February 05, 2003 - 04:30 PM
UTVLOS! Did your bike run at all with the timing off?
  • ThumperWR450F
Posted February 05, 2003 - 04:42 PM
the bike starts right up with the e-start no funny noises or anything.
  • Superbike
Posted February 05, 2003 - 05:42 PM
Why are these shearing so much?
  • Jim_Patterson
Posted February 06, 2003 - 02:38 AM
How did you remove the flywheel. I thought there wasn't a tool out there yet to remove it.
  • utvols
Posted February 06, 2003 - 05:03 AM
My timing was off just enough to have me chasing a jetting problem. It never failed to start or run it just kept running bad. I used the puller from the shop I bought the bike from to pull the flywheel and replace the woodruff key. The jetting I originally came up with is in the bike now and seems to run great at this point.
As soon as I get some more time on the bike I will play around with the YZF jetting some more.
  • charlieb
Posted February 06, 2003 - 06:05 AM
Usually but not always.. when the woodruf key is sheared the flywheel will pull off by hand very easy. not always but most of the time.
  • ThumperWR450F
Posted February 06, 2003 - 10:40 AM
so if i sheared the key than how would my bike start? it still starts just takes a few kicks
  • charlieb
Posted February 06, 2003 - 12:02 PM
Sometimes a sheared key only moves the flywheel a very small amount, so it is possible for a bike to still start since the timing would only be off a little bit.
Also an offset woodruff key is one way to change ignition timing on an engine.
  • WR250fla
Posted February 06, 2003 - 04:44 PM
Jim, I just wanted to tell you that my shop checked my rotor bolt torque and pulled the flywheel off and retorqued several times per Yamaha instructions, as a preventive measure for the woodruff key problem so there must be a tool out there. BTW I've never had I problem yet,but I still think about the woodruff key once or twice every long ride. I am suprised that it didn't happen to more bikes if there was a problem...
  • jonethumpwr
Posted February 07, 2003 - 06:05 PM
WR250fla: Where in Florida ? Lakeland here.
