WR450F mods DO's, DONT'S
14 replies to this topic
  • WR450F_RDR
Posted February 05, 2003 - 10:12 AM
could someone please post a list of the mods to do to a WR450F that work, overall I love the bike, it is just a little lacking in spunk.I am new to this forum so please let me know if this has been dicussed to death and I will search the forum further.
  • yamaharichey
Posted February 05, 2003 - 12:11 PM
Yes it has been discussed extensivly. check on the comments on jetting.
  • Rickey
Posted February 05, 2003 - 02:55 PM
Do: Re-jet-Main#160//Pilot#50//Fuel screw out stock=1 3/4 turn out//take the baffle out of the muffler///take out the top of the air box baffle//check all nuts bolts and blue lock tite///check grease on all linkage and bearings///oh yea cut thottle screw..
  • allinson
Posted February 05, 2003 - 06:41 PM
Do remove the snorkle from the top of air box. These bikes need air. This will take some work, but it will come out. I am also thinking about cutting out the let side plate so it will match the right. This should also allow more air in.
  • wr250rr
Posted February 06, 2003 - 02:35 AM
You may want to check flywheel nut torque. There has been a few problems with woodruff key,s shearing off and is believed to be as a result of it.
I think its supposed to be 47 ft-lbs.
(check your manual) :)
  • WR450F_RDR
Posted February 06, 2003 - 02:50 PM
just wanted to thank everyone for the great info.
  • allinson
Posted February 06, 2003 - 09:02 PM
Cut the grey wire today. I did this on my 426 and was pleased with the results. I am optimistic that the 450 will respond the same.
  • ddialogue
Posted February 07, 2003 - 04:06 AM
Mine runs excellent with the grey wire cut. My dealer did it for me before I picked it up so I don't know how it would have run with it. I don't plan on reconnecting it anytime soon. :)
  • timvv51
Posted February 07, 2003 - 04:37 AM
I want to cut the grey wire but I want to make sure I get the right one. So far I have only found one. It is in the clear plastic 6 prong connector underneath the frame just behind the radiator. It is in the middle of one side of the connector between a red wire and a blue-white wire. Is this it and do you just snip it and tape it right in that area? Thanks for any help. Tim
  • jim-in-so-ore
Posted February 07, 2003 - 05:13 AM
Yes, the grey wire that you have discribed is the one! I didn't cut mine. I very carefully worked the metal tab out of the end coming from the CDI box, then I folded the end over and taped it off, that way if for some unknown reason I can stuff it back into the connector and hook it back up.
  • tetfsu
Posted February 07, 2003 - 11:28 AM
:) :shocked:I'd check on that before I cut it. :D :D Jim, I am not saying your are wrong, but most grey wires that I have heard about have been in a 2 wire loom not the 6 wire loom. I am not sure because I am not the expert, but I'd look around TT before you do it. If you look in the 250F forum there are pics of the job posted.
I did mine last night and it helped in the mid range, like it was supposed to. Good luck.
Just so you know, I am just talking about my 426 and all the stuff I have read, it may be in the 6 wire for the '03.
  • Boozer502
Posted February 07, 2003 - 11:33 AM
has anybody put a switch on the grey wire to change it back and forth between the two ignition curves ?
  • timvv51
Posted February 07, 2003 - 12:18 PM
Boy, that is a good idea. But it is so tight in there I could hardly turn the loom to find the wire. How do you disconnect the connector to get more room to work. It looks like there is a prong on either end of the short side of the connector but that protrusion on the long side is odd looking, is it a fastener also. I sure dont want to screw up the connector. The reason I want to disconnect is to get more room to work so i can just work the pin out of the connector. Tim
  • sabin
Posted February 07, 2003 - 11:50 PM
you can do this, but you have to shut off the engine to make the ignithion switch between modes, at least it was so on 426...
  • allinson
Posted February 09, 2003 - 04:57 PM
Check your wiring digram in the manual. It is the only grey wire on your bike.
