06 WR 450 fork spring change
6 replies to this topic
  • copley
Posted January 20, 2009 - 08:26 AM
How involved is it to change out the fork springs in a 06 wr 450?
thanks,
Jerry
  • travisisdaman
Posted January 20, 2009 - 08:36 AM
I used these to change my seals and springs worked great I had never done anything with my forks before. I used my service manual and these vids and go it done in no time.
  • copley
Posted January 20, 2009 - 08:43 AM
Thanks, never done anything with forks. first time
  • 123BigcoopDawg576
Posted January 22, 2009 - 09:03 PM
its rather easy to do a spring change...the videos above help and if i recall there is a good write up on the net...also the manual walks you through it as well...if you can read and turn a wrench you will be fine:ride:
  • texas_hippie
Posted January 23, 2009 - 05:38 PM
Nothing to changing the springs, just be sure to break the caps loose before you loosen the forks in the mounts! If you're going that far though, I recommend that you go ahead and replace the seals, oil, and sliders while you have the forks broken down. All I used was the shop manual for guidance, and I'd never done forks before either. Putting back in worn seals and sliders would seem counter productive.
  • copley
Posted January 23, 2009 - 06:45 PM
This bike has 250 miles on it. I would like to change out the springs and not remove the forks from the triple clamp if it can be done this way.
  • doctorchopper
Posted January 24, 2009 - 02:11 AM
no, i wouldn't recommend doing them in situe, as you won't be able to get the correct oil level as they are on an angle when bolted on, its nothing to take them off the bike, just remove the front wheel and brake caliper, loosen the bolts in the upper and lower clamps and slide them out, it would be just as quick to take them off because you won't get the springs out with the handlebars left on.
