?JETTING HELP?
3 replies to this topic
  • redhead1331
Posted 04 February 2003 - 06:51 PM
I have had my 02 WR250f for a while now, and i have done most of the free moda and i am very happy with it. But i think its time to move to the next step. I want to change the timing to yz specs, and i want to get ahold of a yz pipe as well. What kind of jetting can I expect to do? bigger main jet? And also if anybody has a YZ pipe they would be willing to let go pleas let me know. Thanks in advance for your responces.
  • Hakka
Posted 04 February 2003 - 06:58 PM
When I changed mine I went from a 170 main to a 175, I changed to an OCFMN needle at the same time as the timing change but you can expect to go 1 or 2 clips richer on your needle and maybe richen the furl screw.
  • redhead1331
Posted 08 February 2003 - 09:39 AM
anybody change to yz timing, AND yz pipe? how am i going to need to change the jetting?, do what hakka reccomended?
  • Rick_Kienle
Posted 08 February 2003 - 09:07 PM
Yes if you change to YZ timing and install the YZ pipe, you will most likely need to richen your jetting. I am assuming you have also removed the airbox lid and unplugged the gray wire. If not do those mods too. With this setup and a P-38 my current jetting is:
Current conditions: 80's, sea level to 1500 ft
MJ #178
MAJ #200
PJ #42
PAJ #100
Needle OBEKP
Clip 4
Fuel Screw 1 7/8 out
Leak Jet #40
Starter Jet #72
