anyone wired up a hydraulic brake switch on wr450
4 replies to this topic
  • trc52001@cs.com
Posted February 04, 2003 - 04:51 PM
my brake switch came in today and i am ready to make this beast street legal. i have never personally installed a switch on any bike so any advise would be helpful. especially if anybody has done this the new wr450f. i want to just use the stock tail light if that is possible. thanks in advance for any info.
jim
  • HighPlainsWR
Posted February 04, 2003 - 06:13 PM
Yeah. Baja Designs (www.bajadesigns.com) has a hydraulic switch for the rear master cylinder for $20. Works great, short enough to miss the subframe. The rear taillignt has an extra receptical for a brake light. Standard auto rear brake light will work off the 120 watt bike lighting system. Check your manual for the hot wire on the rear running light. Tap in to that and do a closure loop on the switch loom. Bada Bing.
  • HighPlainsWR
Posted February 04, 2003 - 06:15 PM
Yeah. Baja Designs (www.bajadesigns.com) has a hydraulic switch for the rear master cylinder for $20. Works great, short enough to miss the subframe. The rear taillignt has an extra receptical for a brake light. Standard auto rear brake light will work off the 120 watt bike lighting system. Check your manual for the hot wire on the rear running light. Tap in to that and do a closure loop on the rear brake switch loom. Bada Bing.
  • BEAN329
Posted February 04, 2003 - 07:12 PM
also, try to fuse the hot side of the switch before the wire goes down to the switch at the brake pedal.
  • Thumpa
Posted February 05, 2003 - 01:55 AM
Instead of looking for the hot wire on the rear running light, can't you just connect to the positive terminal on the battery? An in-line fuse would be a good idea as well.
