Liquid under my 450??
5 replies to this topic
  • earl69
Posted January 18, 2009 - 07:35 PM
Yesterday I rode and when I put the bike on the trailer I noticed liquid under the bike. The bike had sat for about 20 minutes prior to loading and the track wasn't muddy or anything. Today I went out and noticed a clear oily substance on the very bottom of the rear spring.
Any thoughts?? What are the symptoms of a blown head gasket? Or is it just normal overflow from the radiator.
What does a blown rear spring look like?
I know little to nothing about bike maintenance so any infor would be great.
earl
  • rickallen124
Posted January 18, 2009 - 08:41 PM
Look at the bottom of your shock body and see if it's covered in oil. If so than you have a blown shock seal. Sometimes the breather tube will have a mixture of oil and water(condensation from the cold weather) drip out of it which is normal to find under the bike after it's been ridden hard. It will be a milky/oily color. A clear oily liquid would make me suspect shock fluid and a blown shock seal.
  • PAdaytonaman
Posted January 19, 2009 - 06:02 AM
you should also check where your overflow tubes are routed from the carb and the head. If you overfilled the motor with oil it will purge a bit after/ during a ride.
You could always clean everything off after next ride and blow some talcum powder on the shock to see where the leak is coming from.
  • earl69
Posted January 19, 2009 - 08:34 AM
Thanks guys.
earl
  • finthat
Posted January 19, 2009 - 08:40 PM
Can these shocks be rebuilt?
Posted January 19, 2009 - 09:30 PM
Yes, they can.
  • Hot  47 replies
  • On Yesterday, 06:20 PM
