Dual Sport Kit WR450F 2003
9 replies to this topic
  • cloute
Posted July 21, 2002 - 09:31 PM
I know I'm a bit early but I'm looking for a dual sport kit to put on a WR450F. If you can help me could you let me know please! :)
  • XRider
Posted July 21, 2002 - 07:25 PM
I could be wrong but, I think since the bike is already DC power with a battery, you would not have to spend a big chunk of dough on it. Just install a brake switch, signals, flasher and dual fil tail light?
If someone has experiance and knows different, please add your comments.
  • DR.Zaius
Posted July 21, 2002 - 07:35 PM
I did my bike (all DC as well) and it is somewhat a PITA, but well worth the money I SAVED!!!
370 bucks for a BajaDesigns kit, no way.
A 2x filament headlight (hi/lo) may be needed,
turn sigs with a 3 prong flasher from auto zone,
A whole new taillight would be easier, like an Acerbis or UFO, cause the stock bulb socket can only support a single filament bulb. Unless you use a resistor in line with brake switches...
liscinse plate holder, LIGHTED is what I needed...my tail light has a built in plate light.
DOT tires...
and a horn!!!
The best way to add switches for all the crap is get a streetbike one off of ebay, mine is sweet. Even has a built in flasher relay, but I dropped it and it broke!
Actually, you could get everything on ebay, maybe even tires if you're lucky.
All in all, I spent a few bucks over 150 doing it myself, soup to nails, including D606 tires!!!
Plan it all out first, you've got plenty of time. :D
I've got pics of my works in the DRZ forum, check out my page too (up at top of page) for some pics.
PS, don't make fun of the turn sigs, I know they're big, but they were free ok!!! :D
[ July 21, 2002: Message edited by: DR.Zaius ]
  • XRider
Posted July 22, 2002 - 04:47 AM
Thanks for the great info. I am going to research the whole thing. I am going to buy all of the parts before I get the bike. The dealer is going to plate the bike for me. All I need to get started in the state that I am buying it is a brake light, mirror and horn. I can add signals later if I want them.
Nice pics on your site.
If you want to keep being able to type, wear a helmet.
  • hsstar
Posted July 22, 2002 - 07:07 AM
I may be wrong but here goes. Australian wr's come with all the street stuff. When the bikes are released there the parts should fit on the US model. I saw a link in the past of Malyasian models with all the street garb. I can only assume a US dealer may be able to order with the part #'s.
  • XRider
Posted July 22, 2002 - 07:49 AM
That would be the only way to go, OEM!
  • AZWR426
Posted July 22, 2002 - 07:59 AM
OEM...Better find as someone's takeoffs or you might consider a second mortgage from DiTech.
[ July 22, 2002: Message edited by: AZWR426 ]
  • XRider
Posted July 22, 2002 - 08:06 AM
You are most likely correct about that.
I think OEM stands for Only Expensive Equipment.
  • Rich_in_Orlando
Posted July 22, 2002 - 08:19 AM
Originally posted by DR.Zaius:
...A whole new taillight would be easier, like an Acerbis or UFO, cause the stock bulb socket can only support a single filament bulb. Unless you use a resistor in line with brake switches...
Actually, the WR's tail light comes pre-wired for a brake light, so the stock tail light should work just fine.
Anyone know a web site that lists part numbers for non-US Yamahas? I'd like to look at the OEM electrical switch parts for the Australian or European models.
  • XRider
Posted July 22, 2002 - 08:40 AM
If that is true, all you would have to for a brake light is install the switch and plug it in.
I am also interested in getting the part numbers.
