I am wondering what the best and easiest way to gain power out of my baby F would be?
Best Possible Way To Gain Horsepower
Posted 04 February 2003 - 01:43 PM
Posted 04 February 2003 - 02:06 PM
The 250F is in a fairly high state of tune as delivered. A pipe will gain a couple of HP usually at the cost of more noise. Or just moving the power around. Gearing will change the power delivery but not actually change the hp numbers.
Carburation is about as good as possible without going to a fuel injection (which does not exist, yet). Probably the best possible way is a big bore kit. Old timers have been forever saying with regard to 4-strokes....."there is no replacement for displacement".
As for myself....I think my stock YZ goes pretty good. I am also at 200 pounds without gear. In the day when at a "fighting" weight of 165 pounds I really rode well. I am currently loosing that 35 extra pounds. I am confident my YZ will down right rip when back to 165.
search TT for previous discussions on big bore kits.
Posted 04 February 2003 - 02:33 PM
Add a pipe of your choice and re-jet to match
Get a Power Now intake bell to help the low end pull and make for easier starting
Get a Boyesen water pump cover and impeller. The combination of the two reduces parasitic drag and the improved impeller design helps the bike run cooler. Cooloer motor = more power. Factory bikes always have modified covers/impellers for that little extra.
Snap up a Vortex ignition module and replace the stocker. It has better power everywhere.
After these mods examine your gearing for the riding you're planning to do and adjust a tooth or two to maximize your punch.
Keep in mind if you're racing that a suspension calibrated for your weight and riding style is worth more than some extra HP.
Posted 04 February 2003 - 05:15 PM
PK
Posted 04 February 2003 - 05:20 PM
Posted 04 February 2003 - 05:40 PM
or
2. Twist the throttle more
or
3. Learn to ride faster
or
4. Buys an exhaust system
or
5. Run a higher octane gas and speed up the timing. (Just guessing on that one
or
6. Hook some nitras oxide up to it.
Posted 04 February 2003 - 06:25 PM
1. y do u want more horsepower... honeslty these bikes have enough power in them to make any person happy. i mean all of the bikes have so much horsepower that even RC cant use it.. no offense to racing.. and unless u are running in the big leagues with him then y worry.
2. yzracer... no.... upgrading a bike just to be able to twist the throttle a bit more and to ruin an engine with nitras oxide if u arent going for a speed record is a waste.. if anybody thinks about the bikes as they are... they are running grenades.. i mean y are dealing with explosions beneath your crotch every what second???
Posted 04 February 2003 - 06:44 PM
"Carburation is about as good as possible without going to a fuel injection (which does not exist, yet)."
you might want to ask the Cannondale guys about that one. the Cannondale bikes ARE fueal injected.
Posted 05 February 2003 - 01:57 AM
Posted 05 February 2003 - 03:55 AM
Posted 05 February 2003 - 11:02 AM
Prices start at $2500 for the 250F and go up to $3000 if you want the full package with map select options. It is a pretty cool idea but HOLY CROW is it expensive.
Posted 05 February 2003 - 02:13 PM
Posted 05 February 2003 - 04:55 PM
Posted 05 February 2003 - 05:47 PM
Posted 05 February 2003 - 06:12 PM
Posted 05 February 2003 - 06:33 PM
power core 4, or white bros pipe;
softer tires your terrain allows;
lowest tire pressure you can get away with;
race fuel (and rejet for it);
bigger rear sprocket;
vortex ignition;
high-flow air filter.
hotcamsinc.com also sells a race cam, but you in fact already have a race cam in your bike, and there have been occasions when people have had bad results from trying to take these bikes hotter than they already are, fundamentals-wise.
joe
Posted 06 February 2003 - 10:03 AM
I've read and seen pictures of fuel injection on a 250F in a Dutch mag. They were testing it in Veldhoven, The Netherlands. looks pretty interesting. I'll post some kind of translation of the article later. The guys that started this project are located in the U.S. though.
Later more....
Posted 06 February 2003 - 11:25 AM
of course fuel injection is an intriguing idea. but whadda you do when you put a different pipe on it, or go to a hotter or cooler spark plug, or take it to denver where the air is less dense, or take it to Galveston, where the air is super dense and wet, or do any of the hundreds of mods we do all the time. each and every one of these would require a new ignition mapping to be downloaded into the logic circuit controlling the fuel injection system and ignition. sure, cannondale provided a handheld unit for doing just that, but what a load of crap to have to go through just to change jetting for cold weather.
if you look around yamaha's corporate site, they in fact have an in-house project going where they've retrofitted a fuel injection system onto some blue bikes. hopefully they'll keep it in the laboratory for a good long while :-)
joe
