FMF Silencer - Pulling it apart?
11 replies to this topic
  • chriso83
Posted January 16, 2009 - 03:58 PM
Okay, so I thinking, "how hard could it be to open up my FMF Turbine Core silencer to see if it needs servicing?"
"Just remove a few screws, give it a couple of gentle taps with a rubber mallet and pull it apart, right?"
Wrong!
So it looks like I over estimated the little bugger :p or I am doing something wrong.
I checked out the FMF website and even downloaded their PDF for servicing their silencers with little results.
I will admit that I am hesitant hit this thing harder than a moderate tap. I'm trying to keep it all "purty and such" by not bunging it up.
What's the trick to pulling this thing apart?
The instructions looks sooo simple. :thumbsup:
ChrisO83
  • FPMXer
Posted January 16, 2009 - 04:13 PM
The inner tube is connected to the end cap. Drill the rivet's or remove the bolts/screw at the bottom and it should seperate. They say to repack it every 25 hours. Once you repack it listen to the sound of the bike and you will learn when it get louder and needs to be repacked.
  • chriso83
Posted January 16, 2009 - 04:50 PM
I have removed all the screws and have attempted to pull the pipe apart but it's not moving.
  • hodgkins
Posted January 16, 2009 - 05:00 PM
they use high temp silicone to seal it when new. give it a good whack with a rubber mallet and it should start to come apart. use some high temp when you put it back together to keep the drool down.
  • sluggokx
Posted January 16, 2009 - 06:51 PM
+1 ya they can be a bugger to get apart. Like hodgjins said give it a good whack with a rubber or plastic hammer and it will come. My fmf was also hard to get apart.
  • 1000k6
Posted January 16, 2009 - 07:31 PM
I had a hard time with mine recently.
I sprayed lube around it a few times and some hard smacks with a rubber mallet
  • chriso83
Posted January 16, 2009 - 08:42 PM
OK.
I see I have to be more aggressive before it will come apart.
Thanks for the encouragement.
CO
  • mynewcr250
Posted January 16, 2009 - 08:47 PM
yea, you gotta be careful...i just destroyed my fmf shorty because it wouldnt come apart.
kept hammering it with a rubber mallet exactly as fmf say to do, and the welded hinge started to crack and that portion of the silencer bent into the packing material (dented pretty good just from the force of the hinge pushing it down)...then after wacking it more and more the freaking core broke. one end is on the end cap and the other end is on the lip where it connects to the pipe that connects to the expansion chamber.
needless to say, i dont think the last owner ever opened it up...or i just took it apart wrong, which i dont think is the case since we did the same thing to my buddies fmf shorty and it just fell apart with absolute ease.
  • shrubitup
Posted January 17, 2009 - 12:38 AM
There's no need to drill rivets to open up a reasonably serviceable 2T FMF can - ever.
  • zz3gmc
Posted January 17, 2009 - 12:57 AM
I use a little heat from a propane torch around the siliconed end. Dont go crazy with the torch. Mine come apart easily.
  • chriso83
Posted January 17, 2009 - 03:47 PM
Okay, I will give it a little heat and along with some well placed taps with a rubber mallet and hope for the best.
Thanks for the advice everyone.
CO
  • smokinscott
Posted January 23, 2009 - 09:53 AM
Spray some carb cleaner to degum the oil and carbon. That stuff is like glue
1994 KX250 engine parts by Beebstash
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • 5 replies
Handling and steering on 05-07 kx250's by duner929
  • Hot  32 replies
1990 KX 250 Project. by Richleek2040
  • Hot  30 replies
Phathead racing head? by 1999 Kx 250
  • 16 replies
If you own a 2 stroke,please reply once. by dirtbikesrule
  • Hot  5,522 replies
