HELP !!!! No YZ Timing for 03 WR250F ????
5 replies to this topic
  • yamsman
Posted 04 February 2003 - 06:42 AM
HELP!!!!!!!!!!
After doing a TT search on "yz timing wr250f" -- I've just read that the YZ timing can no longer be done on the 03 WT250F. One sample statement:
One of the TT members reported a few days ago, that it doesn't work to change the 03 WR's timing to YZ position, as per the 01/02. The reason is that the 03's new auto-decompression cam will not develop enough compression to start.
Some say it can be -- with new YZ cams. Others -- if I scanned it correctly -- say the YZ cams cannot be used. One put it this way:
The YZ cam won't work for WR timing and the WR cam won't work for YZ timing. That is because the auto-decompression mechanism is installed at a different degree point on each of the cams. When you move the cam timing, the auto-decompression is activated at the wrong time effectively opening the exhaust valves too early (loss of compression) or too late (loss of easy starting).
You now have to buy the YZ for your WR.
Does anyone know for a for sure whether or not the YZ timing can or cannot be done for the 03 WR250F.
If YZ timing cannot be done for the 03 WR250F -- is an 03 WR450F a better choice for a NEW WRF buyer.
HELP!!!!!!!!!!
yamsman
  • Chow
Posted 04 February 2003 - 06:51 AM
If you want YZ timing for your WR, you have to buy a YZ exhaust cam. The auto decompression device will cause the exhaust valve to open too far if you time the WR cam to YZ specs i.e. 12 teeth on the cam chain instead of 13 teeth. I was able to kick start my 03 WR with YZ timing, but it would not electric start. I have a YZ cam on order. Yamaha said that the CA warehouse had them in stock.
Chow
  • jetdave
Posted 04 February 2003 - 06:57 AM
Buy a 03 YZ cam. Sell me your used 03 WR cam. You will recovery half the cost. WR timing works for me and I not afraid to admit it. I will have an auto decompression 01 WR 250f. You will have your hit. The whole world is happy. :)
  • Chow
Posted 04 February 2003 - 07:02 AM
If I don't lose any bottom end power with the YZ cam, I'll do it. I should have my cam in this weekend.
Chow
  • MitchPeters
Posted 04 February 2003 - 07:37 AM
I think you will gain low end hit and it will rev faster.
I will also buy a used '03WR cam. :)
  • jetdave
Posted 06 February 2003 - 05:05 AM
Chow, I will buy your cam. Check your personel message.
