Oil...
6 replies to this topic
  • TRUE_2_YAMAHA_001
Posted January 15, 2009 - 07:42 PM
So after i blew the engine up completely in my 2001 WR 426, for obvious reasons there is alot of metal shavings in the frame due to the fact that the oil is in the frame.
anyone got any ideas on how to get the metal shavings out of the frame?
thought alot through but finding reasons y all my ideas will not work.
I would like to hear some of your ideas.
thanks in advance.
  • brad the best
Posted January 16, 2009 - 12:42 AM
spray a crap load of brake clean in there and blow it out with compressed air .
pour gas in there and keep pouring gas and blow it out with air .
more brake clean
more compressed air
flush it with some oil .
thats what i would do .
what are your ideas? why wont they work ?
  • matt4x4
Posted January 16, 2009 - 04:53 AM
you really shouldn't have any shavings in your frame - there's a screen in the sump to filter out larger debris, talking about filtering - then there's a filter in your engine that should get all the fine stuff...
After my engine blew a bearing there was lots of stuff in the sump when I split it, but the frame was clean - also has another screen at the frame so any larger contaminants that may come in through your filler don't make it through the system.
  • TRUE_2_YAMAHA_001
Posted January 18, 2009 - 08:06 PM
more brake clean
more compressed air
flushing it with solvent based products but it will retreat into the metal and in turn break down the oil.
and the same with gas, just not to the same extent.
  • TRUE_2_YAMAHA_001
Posted January 18, 2009 - 08:07 PM
you know, i never really thought about it that way.
i just assumed that the filter did the filtering on the wat into the engine, not the way out.
  • brad the best
Posted January 18, 2009 - 08:12 PM
well there are three filter on the bike , one inline . the oil filter and the pick up .
  • tntmo
Posted January 20, 2009 - 11:36 AM
Use diesel fuel or kerosene, flush it out a few times and then flush it with some oil. Even though there are filters in the system, I'd still flush it out.
