New jetting = New problem
4 replies to this topic
  • lomitamike
Posted February 03, 2003 - 07:07 PM
01 WR 426. YZ exhaust, OBELN #3, #48 Pilot, 100 PAJ, 168 main, screw 1 turn out. Problem is hesitation at 1/4 or 1/3 throttle. Elevation 0 to 8000'. Any suggestions appreciated. Mike
  • dominator426
Posted February 03, 2003 - 11:44 PM
If opening your PFS more than 1 turn makes it worse, try a smaller PFJ or position #2 on your needle.
  • blue_beast_wins
Posted February 04, 2003 - 12:14 AM
Your clip position is good, but pull your mj back to a 162 with a 200 maj your low speed circut sounds all wrong, have you tried a 75 paj with a 40 pilot??
  • r1superstar
Posted February 04, 2003 - 05:51 AM
Here is what I'm running:
45PJ (42 was stock), 75PAJ, Stock needle #4 position, 168 MJ (165 was stock), 200 MAJ, PS 1-3/4 (2-1/8 was stock). I am also running a hotter spark plug. Your PAJ seems too small, your PJ seems too big.
My 02' WR 426FP has the gray wire mod, baffle out, and lid removed. I ride anywhere from 4300 ft. to 8000 ft.
Bike runs pretty damn good, but I am going to try a different needle soon.
  • Taffy
Posted February 04, 2003 - 12:05 PM
drop the needle once
then try dropping it again
possibly try a third and if you've gone too far-put .5mm washer under the needle clip and if that doesn't work then pop the needle up one.
note i don't mention the clip: JUST NEEDLE
Taffy
